New E55 owner dyno results!
Old 09-28-2018, 08:38 PM
Lriver1004's Avatar
2012 CLS63
Hello all,
I recently acquired 2005 e55 and just had it dyno tested today to see where I am at before I start doing a few mods. The car is stock besides deleted resonator and secondary cats. I already ordered a bosch 010 pump and plan on doing the split cooling using the BMW reservoir. Currently, my IATs are crazy high (150f+) and were at 195F after the dyno. The dyno was an awd Mustang dyno typically used for subarus. Let me know what you guys think!
Old 09-28-2018, 08:40 PM
tlambert's Avatar
2005 E55 AMG
What numbers did you turn?
Old 09-28-2018, 08:42 PM
Lriver1004's Avatar
2012 CLS63
Well, I thought I attached a pic of the graph but it's not showing up. The max numbers were 362hp and 423tq
Old 09-28-2018, 08:43 PM
Lriver1004's Avatar
2012 CLS63
How do I attach a picture?
Old 09-28-2018, 08:45 PM
drothgeb's Avatar
2005 E55
Did you Dyno it to get peak IAT numbers?! Because that's all you gave us! Also, your intercooler pump is dead. Replace it an enjoy some consistent power.
Old 09-28-2018, 08:46 PM
drothgeb's Avatar
2005 E55
Use the button that looks like a picture haha. Also don't waste your money on the split cooling :-P it will provide ZERO benefits other than a thinner wallet.
Pmarino (09-29-2018)
Old 09-28-2018, 08:47 PM
Lriver1004's Avatar
2012 CLS63
Well the lowest IAT temp I saw was around 125F. That was for the first pull and it kept climbing from there. As stated in my post, I have already ordered a bosch 010 pump from fcpeuro.
Old 09-28-2018, 09:01 PM
Lriver1004's Avatar
2012 CLS63
Finally got it to upload!
Old 09-28-2018, 10:37 PM
tlambert's Avatar
2005 E55 AMG
Are you in Greenville? I’m in Lexington SC
SD Racing looks like a nice place. Checked it out on FB
Old 09-28-2018, 10:42 PM
Lriver1004's Avatar
2012 CLS63
Sure am. Yeah it's a cool little place. The guys there were thinking it would dyno a lot lower!
Old 09-28-2018, 11:02 PM
w204_racing's Avatar
C300 sport 2008
that’s horrible
Old 09-28-2018, 11:25 PM
tlambert's Avatar
2005 E55 AMG
looks like they have a nice place.
post up some pics of your car!
Old 09-28-2018, 11:40 PM
Lriver1004's Avatar
2012 CLS63
Originally Posted by w204_racing
that’s horrible
Eh, it's a mustang dyno. They tend to read low
Old 09-29-2018, 12:40 AM
Lriver1004's Avatar
2012 CLS63
Can anyone chime in a tell me if these numbers are normal for a stock E55? I know I am heat soaking bad and there is some power to be gained from changing the ic pump.
Old 09-29-2018, 06:18 AM
Fantomas's Avatar
2006 ML350, 2005 C55, 2004 E55
Your timing is being retarded due to high IATs, you're definitely not making the power you will be with a new pump, first thing I bought for my E55 was a 010 pump.
Old 09-29-2018, 07:06 AM
PieRat's Avatar
CLS55
With a pump youll be within expected range of power in my opinion.
Old 09-29-2018, 08:10 AM
Lriver1004's Avatar
2012 CLS63
Thanks guys!
Old 09-29-2018, 09:04 AM
lseguy's Avatar
2005 c230
Mustang (vs Dynojet) Dynos read low. And you have a bad IC pump. For comparison, my 2006 dynoed at around 436hp and around 467 torque. Admittedly that it with a basic Eurocharged tune but the bulk of the difference between your #'s and mine is brand of dyno and a functional IC pump to keep IAT's down. My second and third run #'s were closer to what you have, but still not quite as low
Old 09-29-2018, 03:21 PM
Lriver1004's Avatar
2012 CLS63
Were your numbers on a dyno jet or mustang dyno?
Old 09-29-2018, 04:57 PM
lseguy's Avatar
2005 c230
Dynojet
Old 09-29-2018, 07:58 PM
tw2
tw2's Avatar
2005 E55 AMG, 1991 MR2
390-420whp for a stock car on the higher reading dyno's would be about right. In good condition of course.
Old 09-29-2018, 10:06 PM
PieRat's Avatar
CLS55
I had 440 whp on dyno dynamics with 77mm pulley, kleemann and tune. Now i upgraded cooling and removed sec cats hopefully some more.
Old 09-30-2018, 12:51 AM
Lriver1004's Avatar
2012 CLS63
Sounds good! I'm doing some cooling mods and headers/tune first!
Old 09-30-2018, 02:03 AM
Lriver1004's Avatar
2012 CLS63
So the 362whp my car put down on a mustang dyno would put me in that range on a dynojet!
Old 09-30-2018, 02:11 AM
tw2
tw2's Avatar
Yes probably. All dyno's are a bit different so comparing different cars on different dyno's is never going to be accurate. Some stock cars hit 400whp on dyno dynamics. I would be more concerned about the torque curve, it looks like it drops off sharper in the higher rpm than most.
Quick Reply: New E55 owner dyno results!
