Will 18x9.5 +28 wheels fit the front?
Old Oct 17, 2018 | 12:48 PM
EvoTechnik's Avatar
E63 AMG
Has anyone tried fitting a 265/35 18 setup on 18x9.5 +28 wheel? Not sure if the fronts will fit wanted to see if this was possible.
Old Oct 17, 2018 | 02:46 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
The issue, I see is finding the right wheel offset to fit a 265/35-18 onto, that gives your enough clearance for the calipers. That don't push the wheel out past the front fenders thereby causing a rubbing issue on suspension compression and not rubbing the inside of the fender liners.
Old Oct 17, 2018 | 02:55 PM
EvoTechnik's Avatar
E63 AMG
The wheel itself will clear the calipers no problem, I've checked the clearance on the upper control arms. Unclear about the poke. Trying to see if anyone has tried this with out having to pull or roll the fenders. I've heard of 275s on the front but not sure what offsets they are running.
Any help would be appreciated.
Old Oct 17, 2018 | 03:09 PM
Yuille36's Avatar
A 275 is awfully wide for the front wheels, I'm running that on my rear wheels. Are you trying to increase front end grip?
Old Oct 17, 2018 | 04:46 PM
lseguy's Avatar
2005 c230
to me, seems like asking for trouble. Seems too aggressive for the fronts..
Old Oct 17, 2018 | 04:51 PM
Yuille36's Avatar
What size rear tire are you running, if the fronts are 275?
Old Oct 17, 2018 | 04:55 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
That's what I'm running on my car (with 275's, actually), and yes, they will fit, but they stick out a little too far for my taste.
To make it all work properly, I put on a set of the adjustable upper control arms to pull the top of the wheels in, and also slotted the lower arm holes in the frame to pull the bottom in, thereby getting my camber to about -0.5 deg. and the wheels just flush with the upper fender arch.
Old Oct 17, 2018 | 04:58 PM
Yuille36's Avatar
What is the ultimate purpose for all this in the first place. Help me understand this!
Old Oct 17, 2018 | 05:02 PM
JoeJErnst's Avatar
A) I autocross my car from time to time, so I wanted much more grip, especially up front
B) More importantly, it looks friggin' awesome!
Old Oct 17, 2018 | 05:05 PM
tlambert's Avatar
2005 E55 AMG
#2. Isn’t that the most important reason.
Old Oct 17, 2018 | 07:19 PM
EvoTechnik's Avatar
E63 AMG
You know what I just realized my old e55 had cls 55 wheels when I bought them. They had CLS rear wheels on all 4 corners with 275/35 18s
correct me if I'm wrong arent the cls55 wheels 18x9.5 +28?
I guess I answered my own question.
Old Oct 17, 2018 | 07:47 PM
KAMG's Avatar
2005 C55 AMG (sold), 2005 E55 AMG
CLS55 wheels are 19s (8.5 et 25 front, 9.5 et 28 rear). I have them on my E55 with 245/35/19 fronts and 275/30/19 rear. The rear rubs if I'm too low, no issues with the front so far. I think the non AMG 211s had an 18 inch version of the CLS55 5 spoke style wheel...maybe those were the ones you had?
Old Oct 18, 2018 | 08:23 AM
Yuille36's Avatar
I prefer the staggered setup myself. But I do think if your car is lowered, you'll have rubbing issues with such wide front tires.
Old Oct 18, 2018 | 02:13 PM
the youngn's Avatar
2007 E63 Wagon
Shouldn't have an issue with that. I'm running 19x9.5 with a lower offset than that without issue while lowered with natural camber.
Old Oct 18, 2018 | 02:52 PM
EvoTechnik's Avatar
E63 AMG
what size tire and offset are you running?
Old Oct 19, 2018 | 12:45 AM
manual_tranny's Avatar
2003 E55
CLS also came with 18's. I've got the CLS 18's in the back of my E55 with 295/35 rubber. There was just a little bit of rub when I hit bumps, so I reprogrammed a higher ride height for the rear.
Old Oct 19, 2018 | 01:26 PM
KAMG's Avatar
You mean the split spokes that came on the CLS500? The ones that look exactly like the stock E55 wheels but just wider and lower offset?
Old Oct 19, 2018 | 03:24 PM
2003 E55
Yup, exactly
Old Oct 19, 2018 | 03:51 PM
EvoTechnik's Avatar
E63 AMG
the picture I posted of the double spokes is what I had before. Not sure what the offset was but I think they were 18x9.5 +28
Old Oct 19, 2018 | 04:07 PM
2003 E55
CLS 9.5x 18" ET28 is correct
Old Oct 19, 2018 | 04:37 PM
KAMG's Avatar
Yeah you had the CLS500 wheels. Stock E55 wheels are 18x8 et30 and 18x9 et39. The CLS500 and SL550 wheels are a popular upgrade for the E55 guys. They look the same but are wider and lower offset
Old Oct 20, 2018 | 10:48 PM
EvoTechnik's Avatar
E63 AMG
Just fitted them today with 265/35 18 Continental tire on the front. They sit really flush to the fender but the tire has a slight stretch on the 9.5". On my stock rear wheels I have 265/35 18 nittos and the tires are pretty square on the 9.5. I'll put the rears on tomorrow and see how they look.
Old Oct 21, 2018 | 05:33 PM
EvoTechnik's Avatar
E63 AMG
18x9.5 +28
front.
Old Apr 1, 2024 | 04:18 PM
05 w211 e280's Avatar
2005 w211
Smile rubbing
18x9.5 +28
front.
Do you have any rubbing issues with this setup wondering cause im thinking 19x9.5 ET30 offset for the front
Old Apr 1, 2024 | 05:42 PM
EvoTechnik's Avatar
E63 AMG
No issues with rubbing also didn’t need to roll the fenders. It might vary depending on the tire as well. The Continental tires have a tapered sidewall compared to some other tires.
