Drivers Side Keyless Go Door Handle
Old Oct 29, 2018 | 09:47 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Since the drivers door handle is the most used handle on the entire car. It was bound to fail at some point, but surprised it lasted for 11 yrs before failing.
Well last Friday, I finally did it. I had my guys at Benz Elite Automotive replace my Keyless Go door handle, after about two months dealing with this issue.
The door handle wouldn't unlock, and the lock button worked intermittently. So the only way to access the car, would be to either press the unlock button on the keyfob or grab the drivers rear door handle. This was simple remove and replace, took about 20 minutes in total. And the cost was only $396, door handle $260 and the labor $115 plus applicable taxes. They also reset my summer open/close feature.
Old Oct 29, 2018 | 05:01 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
$260 is a lot for a door handle. I got mine for $210 shipped from some site and it took my friend about 10 minutes to swap it out.
Old Oct 29, 2018 | 07:09 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
I am looking forward to using Benz Elite automotive when I need them - I've read a lot of good things, some definitely from you.
The handle replacement, FYI, is a 10 minute procedure even for a novice. I had to replace mine a few months ago and it was very easy.
Old Oct 29, 2018 | 11:05 PM
MSG 55G's Avatar
Veteran: Army
2006 E55
could you post the site you bought your handle from?
Old Oct 29, 2018 | 11:21 PM
tlambert's Avatar
2005 E55 AMG
$115 for labor to install a door handle.....if that included painting the small section first and the install maybe that’s not too bad.
Old Oct 30, 2018 | 04:06 AM
cetialpha5's Avatar
The price of the handle varies depending on the color of the door handle.
https://www.oediscountparts.com/parts/2006/Mercedes-Benz/E55%20AMG/Base/?siteid=215242&vehicleid=186925&section=BODY%20HAR DWARE&group=FRONT%20DOOR&subgroup=LOCK%20%26%20HAR DWARE&component=Handle%2C%20outside
Old Oct 30, 2018 | 10:09 AM
4ShoreRunner's Avatar
2017 MB GLC300 4Matic Sport Package :: 2009 E63 AMG
I can second Yuille36's recommendations for Benz Elite Automotive - I used them per his recommendation and I will continue to do so. Headbolts, lifters, etc. was a hard pill to swollow but they made it easier with the amount of care they took in the job and genuine pride they take in their work.
Old Oct 30, 2018 | 10:35 AM
Yuille36's Avatar
4ShoreRunner,
They have relocated to a new shop. Their address is 2809-C Dorr Ave, Fairfax, VA 22031. They are expanding, and will have a detailing bay, door dings, paint protection film and tint bay. A larger reception area, with work stations for computers. I will be headed back to see them in 2 weeks, to remove small door dings in panels. They have a guy that works miracles with door dings. So am I worried that I might have paid a little too much, to have my door handle replaced. No...because these guys, have taken care of me so many times on small stuff, and I didn't have to pay for it. Example. Two weeks ago, I dropped by to have them install my new HID bulbs, because I couldn't get my fat hands inside the tight space to attached the bulb retaining rings to the headlight assembly. As it never stayed attached and would always loosen up, thereby causing the light projection to be diffused on the road, and I couldn't see sh*t on my morning drives into work. Well Eddie installed it no questions asked, and told me not to worry about it, when I offered to pay for his services.
Old Mar 23, 2019 | 02:11 PM
Rovel's Avatar
2007 E63 Amg
I hope somebody can help me here. I was switching driver side door handle. Put the new one in and then realized that the keyless go wire was getting on the way of the glass. I tried reinstalling the door handle multiple times with no success. Eventually some plastic that looks like a retainer for the keyless go connection came loose How do I fix it? Should I take the door panel off? If I should remove the door panel, how will I glue that black foam thing back on the door?
Old Aug 5, 2019 | 09:20 AM
90lxracer's Avatar
01 E55
Bump..
Curious about Benz Elite since I'm in the NOVA area as well..
Old Aug 5, 2019 | 09:43 AM
Yuille36's Avatar
You may need a tech to take a look at this for themselves. I can't say one way or another.
Old Aug 5, 2019 | 09:53 AM
Yuille36's Avatar
Originally Posted by 90lxracer
Bump..
benzelieteautomotive@gmail.com
http://benzeliteautomotive.com
(703) 370-1221
2809C Dorr Ave. Fairfax VA 22031
What would you like to know about them? Give them a call if your have questions. Tell them William sent you.
Old Aug 5, 2019 | 12:14 PM
Worth the wait's Avatar
2006 E55
I have worked with Benz Elite for over ten years. They were even instermental in helping me pick out which E55 to buy in 2009
I have absolutely nothing bad to say about these guys at all! Quite the contrary. In fact, I probably would have moved on from my car several years ago if they weren't around. I am coming to the end of an EXTENSIVE refresh of all the mechanical, suspension, interior and exterior components my 2006 E55 and Benz Elite has performed at least 20 different jobs for me during this process. When they could, they reduced book hours to save me money. While I primarily use Eddie for my work (he is a E55 owner himself, Emile and the crew are all top-notch.
I have always felt like I have been treated more than fairly in regards to price, workmanship and attention to detail. I have saved $1000's of dollars over the dealer for much better service.
Like any customer service relationship, the more loyal you are to the shop/brand/service provider, the more loyal they are to you.
Cheers!
Brian
Old Aug 5, 2019 | 01:23 PM
Yuille36's Avatar
Cheers!
Brian
Well said Brian. But loyalty goes both ways, the more loyal you are to them by using their services, the more loyal they are to you by discounting some of their labor hours.
A good friend of mine that happens to be a AMG Master Tech and Shop Foreman at a local MB Dealership, told me after my warranty has expired on my E63 to not bring the car to the dealership anymore.
But to take it to Benz Elite Automotive, he told me all about Emile and Eddie before I ever met them. He told me that they worked under him, and that I can trust their work on my AMG.
Since then, I used them exclusively, for all my vehicles. They work on not only Mercedes, but BMW, Audi and Porsche. But their bread and butter is Mercedes.
So when I tell you, that you can trust their work, it's coming from past experience developed over the years.
I have had A-E services done here. Occasional oil leaks addressed, suspension modes, exhaust, detailing and ceramic coating done.
And more recently, interior modification. They are all a good group of people that you can trust. Emile, Gretta, Eddie, Jessie, Larry and Angel
Check them out if you ever need work done on your vehicle.
Old Aug 5, 2019 | 05:06 PM
90lxracer's Avatar
01 E55
Cheers!
Brian
Quite the endorsements! I'l have to give them a ring. They're 13 miles away from where I work.
I bought a E55 over the weekend, and I'd like to baseline a couple services for me.. to compliment the VMI I received with the car. I'd be interested in getting some paint correction/detailing work as well. The car does have lower miles, but wasn't garage kept.. so.. it needs little cosmetic love.
Old Aug 5, 2019 | 07:15 PM
Yuille36's Avatar
I had them perform paint correction and ceramic coating, and I’m very pleased with the results. And to be totally honest, I get a lot of compliments and thumbs up from other drivers.
Old Aug 5, 2019 | 08:05 PM
90lxracer's Avatar
01 E55
Lookin'' sharp for sure!
curious the time and cost involved.
To get back to the intent of this thread.. is there a decent place to source a driver door handle. Mine is dead.. but the rest are good to go.
Old Aug 5, 2019 | 08:56 PM
Yuille36's Avatar
The time only took like 15 minutes to remove the old and install the new. I let Benz Elite source the part for me, is was like $200 for the keyless go handle. But there are dealer sites that have online parts departments like MB of Peoria, where I purchased my steering angle sensor they installed last Friday.
But there are other sites as well. https://www.autohausaz.com/catalog/k...0door%20handle
But you can shop around and get prices from your local dealerships. It’s good to make friends at the dealerships to take advantage of employee discounts, which I use a lot .
Old Aug 6, 2019 | 12:57 AM
Strigoi's Avatar
Yullie has to be getting paid by these guys. He's on their nuts hard lately.
Old Aug 6, 2019 | 07:44 AM
Yuille36's Avatar
I'm not getting paid, and you can say whatever you want. But I can guarantee my maintenance and repair costs are cheaper then yours.
