BILLET FUEL PUMP COVER
Old Nov 1, 2018 | 12:32 PM
SICAMG's Avatar
2005 e55 AMG
A while back someone showed a billet fuel pump cover that eliminated the burned connector problem.
Can't seem to find it for sale anywhere as I am swapping out my pumps for Aeromotive's and replacing the driver side assembly do to a small leak.
Thank's
Old Nov 1, 2018 | 12:44 PM
Notdke9fdkfjekrjrkj123's Avatar
https://mbworld.org/forums/w219/685476-billet-fuel-tank-lid-drop-pumps.html
Old Nov 1, 2018 | 06:20 PM
Das_it16's Avatar
2004 E55 AMG
Thank's
I have one. Shoot me a pm.
Old Nov 1, 2018 | 06:30 PM
DavesMeanE's's Avatar
Former Vendor of MBWorld
93' 500E, 95' Corolla
I make them What would you like to know?
Thanks!
Dave
Old Nov 1, 2018 | 08:06 PM
SICAMG's Avatar
2005 e55 AMG
OK I have seen two versions of this. One has the outlet AN fittings and the other is really a stock replacement cover with a much better fuel pump connector. Do you make both?
Old Nov 1, 2018 | 08:29 PM
Never seen the 2nd one you are referring to. Mine does have a much improved wiring solution, with 12ga ethanol safe wiring. Plenty of capacity for pretty much any fuel pump you want to run. It also has a factory connector in integrate to the stock wiring harness.
Dave
Old Nov 1, 2018 | 09:14 PM
SICAMG's Avatar
2005 e55 AMG
Old Nov 1, 2018 | 09:15 PM
SICAMG's Avatar
2005 e55 AMG
Not yours?
Old Nov 2, 2018 | 08:37 AM
Not yours?
That one's not mine
Thanks!
Dave
Old Nov 2, 2018 | 08:56 AM
https://mbworld.org/forums/w211-amg/584658-my-fuel-tank-recall-alternative.html
Old Nov 2, 2018 | 01:18 PM
If you only need better wiring:
https://vrpspeed.com/index.php?route=product/product&path=60_100&product_id=429
Old Nov 2, 2018 | 04:49 PM
SICAMG's Avatar
2005 e55 AMG
Thanks for the info. I contacted Rockthemullet since he made them.
Wiring is not really the problem as I run a low pressure system so no melting. Just looking for a better top that will never go bad in the future ....but a better connector is a big plus.
Old Nov 5, 2018 | 10:58 AM
