2007 E63 valve cover replacement
#51
Any other opinions on whether replacing plug seals is a must?
#52
I called my dealership today for a quote on the plug rings and they wanted $9 per ring....absurd! Especially when the “kit” is $40 each side. Advanced Auto parts has some for about $3.50 each.
#53
1. My ignorance of the process as this car is new to me 2. Cheaper than dealership 3. FCP lifetime warranty replacement
Now I'm in the mental debate whether not I should do the plugs or not. I started to get a very slight tremble from the engine lately at idle in park. RPM needle is steady as can be. Don't notice it driving. I thought that the leaky gasket may have a role in that or possibly oil is getting in the plugs?
#54
I'm also new to this car. $9 is craziness. Ill go grab some from AAP. Thanks for the heads up!
#55
#56
I simply just typed in my 09 E63 and it’s the only part that showed for the spark plug tube seals: https://shop.advanceautoparts.com/p/...lug+tube+seals
#58
The only difference with the M156 from 2007-2010 was the valve cover when they changed from Aluminum to Plastic on the W212 platforms,
farkis644 (01-29-2019)
#59
#60
2008 S63
This must be why I still have a leak at the top passenger side cover. What are the points that need sealer? In the channel itself with the gasket or on the outer round part? Can someone illustrate the points?
#61
The first time replaced the valve cover, I used no sealer, it leaked bad after a few days, especially at the passenger top. The second time I put some sealer in the channel and tried to tighten the bolt this corner first. It worked for a few months. I think I still have a tiny leak at this corner. I checked it almost everyday and only see very small leak once a while. This is the plastic valve cover, I have no problem with the original valve cover. I don't know if I bought a bad plastic valve cover. Let me know if you have a solution.
#63
Yeah, too large. Mine were still soft and in good shape as Dustin also said so I reused them. I put a small bit of seal on them as an extra step. Not ideal but I couldn't get the parts on Sat. Next time I will prob just get the after market kit that includes them.
#64
So you used on the corners outside the channel? I am going to redo mine, for the 3rd time. Anyone who plan to redo it, be careful with the bolts that come with the plastic valve cover, they are not as strong as the original ones. I had to reuse the old bolts, I got 3 broken head for the new bolts already.
#67
SPONSOR
2007 Mercedes E63 AMG
that's a shame...do you know if you've bottomed out the valve cover? there is a metal sleeve that will bottom out letting you know to stop tightening. i'm almost certain that the rubber gasket crush wouldn't cause enough tension to stretch a bolt.
#68
Yes I have bottomed out the valve cover. The gasket that comes with the plastic valve cover is small and thin. There is no gap between the top and bottom valve cover. If there is, it's just a very tiny gap. Not like the original ones.
#69
SPONSOR
ya...from what i recall my mechanic said...only a few turns before he bottomed out the plastic cover. not like the original metal one. he said he stopped because he didn't want to snap the valve cover like the previous dealer did to my metal one. he did mention for me to keep an eye on it because it was tightened VERY lightly which bottomed out the gasket. so light that he couldn't even meet the torque spec.
hasn't leaked since.
#71
Can you please show me how to get the part number for gasket and bolts? The diagram shows #250 and #280/285 ??? Of course for the plastic valve cover. The gasket for the original aluminum valve cover looks big for the plastic vc. After all, my car still has the leak! Thanks.
#73
Just in case if anyone needs, here is the collar screw for that plastic valve cover. The original screw for the aluminum valve cover is stronger but it doesn't have the protection collar.
Part #: 010-990-67-04
#74
SPONSOR
for those of you who were curious here is a picture of the bolt required for the updated valve covers. the new valve covers are not threaded so upon first installation these screws will self tap new threads. just he sure you are correctly aligned. they should self center as you do have a hole but just take your time to ensure you're straight.
N 000000 002179
N 000000 002179
Draven69 (11-08-2021)
#75
A very HUGE thanks to you two folks. hachiroku and dustinN have both saved me the aggravation of locating those elusive ignition coil pack screw part numbers that are required for the replacement plastic valve cover assembly. Many thanks indeed. At 191K miles, those metal alloy covers started to leak from the passenger side. Yet, upon applying torque to the driver's side on replacing the gasket, a hairline fracture propagated itself which made all loads of fun!
dustinN (11-11-2021)
