WHICH LSD is Better for E55?
Old May 29, 2020 | 09:45 AM
  #51
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Originally Posted by MSG 55G
Pulled the trigger and got it installed today. Wavetrac LSD, Indy shop popped it in for a reasonable price. Haven’t had chance to fully test out but just want to update my post and close it out.
Definitely let us know how it works out. Straight line, slight steering wheel input (such as entering a merge ramp while accelerating hard), turning corners hard, concrete surface, new asphalt, old smooth asphalt, etc, etc.
Old May 29, 2020 | 01:35 PM
  #52
MacMan's Avatar
E-55 AMG Wagon
Thanks for the update. I look forward to hearing your driving impressions.
How many hours did the shop take?
If you are still in OC which shop did you use if you feel like you can say?
Old Aug 11, 2020 | 12:39 PM
  #53
kjdeutin's Avatar
C63 AMG
Hey guys, I wanted to see if the following differential part numbers will fit a 2003 E55 AMG:
-A2303500349 bearing
-A2303500249 bearing
I see in the beginning of the thread that it fits a 2004, but I'm not sure if anything changed. My guess is that they do fit. Thanks for the help!
Old Aug 17, 2020 | 05:27 PM
  #54
jetstream's Avatar
2006 CLS55
Driving impressions?
So, after 3 months of driving, was the LSD purchase worth it?
Old Aug 17, 2020 | 06:20 PM
  #55
MSG 55G's Avatar
Veteran: Army
2006 E55
I had Benztec of El Monte installed, took them a day or so, picked it up the next afternoon. Very reasonable cost.
sorry for the delayed response...
jet...after the LSD installed, I ventured to other mods and really was driving her conservatively. I just installed the SGA Valve Body last week and in the “breaking in” stage then I’ll be able to test out the LSD. Might do a new write up on my recent mods (92TB, meth, BBV, and VB). I’m pulling trigger on Force Induction Interchiller today so there’s a 3-4 weeks wait period for delivery. 😃
Old Aug 17, 2020 | 06:49 PM
  #56
jetstream's Avatar
2006 CLS55
LSD and other mods.
I look forward to your perceptions of these mods. I am particularly interested in the 92mm TB. I have seen lots of info on the 82mm, but nothing on the 92mm. Are you concerned about the “hiccup” which seems to plaque some of the 82mm TB? Did you consider the “Active” interchiller instead of FI ?What is BBV and VB?
Old Aug 19, 2020 | 03:35 PM
  #57
MSG 55G's Avatar
Veteran: Army
2006 E55
so I added 92TB and blocked the bypass valve along with installing VB. Just yesterday I swapped my 68 fixed pulley to 70 scp and with that switch it made her performs so much better. I did a couple rips today and I love all the recent mods. Unlike prior to the pulley switch, it was running hot, even with a killer chiller and meth. I’m enjoying the heck out of her now, VB, LSD, HSTC all in one is hard to tell which makes a difference. I’d recommended one or all if possible.
Old Aug 19, 2020 | 03:39 PM
  #58
tlambert's Avatar
2005 E55 AMG
HSTC?
Old Aug 19, 2020 | 04:04 PM
  #59
MSG 55G's Avatar
Veteran: Army
2006 E55
Originally Posted by tlambert
HSTC?
High Stall Torque Converter
Old Aug 19, 2020 | 05:32 PM
  #60
tlambert's Avatar
2005 E55 AMG
Ah thanks!
Old Aug 28, 2020 | 02:12 AM
  #61
benzokirk's Avatar
Veteran: Air Force
2008 E63 AMG, 2018 VW Golf R
Enjoying the revival of this post, and it's timely for me since I've had my Wavetrac sitting on the workbench for close to a year, and it's finally getting installed Monday. Also installing an F1 Rear Camber Kit at the same time.
Old Sep 6, 2020 | 02:42 AM
  #62
MSG 55G's Avatar
Veteran: Army
2006 E55
SGA Valve Body
https://www.facebook.com/groups/AMGE...5703474642227/
I haven’t done full WOT on 3rd since all the mods but I found this video on one of the AMG Facebook by Aaron B showing off his SGA VB. looks like a hoot! Hope my VB will shift as fast...lol
Old Sep 6, 2020 | 11:31 PM
  #63
drothgeb's Avatar
Veteran: Navy
2005 E55
Just to chime in with some wavetrac longevity here, 2 years on mine, daily driven, and 100+ trips down the strip. Zero issues, and def helped out with the traction, also allows a proper burn out.... as before I would get peg-leg water box burnouts.
Old Sep 6, 2020 | 11:46 PM
  #64
PieRat's Avatar
CLS55
mine going hard too....just ripped my subframe bolt through so maybe worth replacing those with install gonna try do a helicoil tomorrow Yolo.
Old Sep 6, 2020 | 11:57 PM
  #65
tw2's Avatar
tw2
How do you guys find it in winter, cold, wet conditions. It's rarely less than 40 Fahrenheit here but the summer tires don't have much grip left.
Old Sep 7, 2020 | 12:07 AM
  #66
PieRat's Avatar
CLS55
car just plain sucks in the wet..better with lsd way better but still needs drive to 2 more wheels or half the torque lol..
