NTG 2.5 Retrofit - No AM/FM Radio Reception
I have searged endlessly to no avail. I am having a problem with ny NTG 2.5 retrofit. I purchased a command, main amplifier, sub amplifier, SDAR and media interface from a 2009 E550, as well as a conversion harness from CommandOnline. Everything works with the exception of 2 things:
1) No radio reception for all AM/FM stations
- The harness I received from CommandOnline has a splitter from dual white fakra at the back of the command to a single that you have plugged into the black fakra that was connected to the AGW previously. There is a double white fakra on the SDAR that has nothing plugged into it. I assume this is my problem? If so, what do I run to this?
2) Can't communicate with the nodules on the MOST loop but they all work
- I assume this needs some programming with Star DAS which I have tried to no avail. Can anyone share with me the steps to perform in Star DAS?
Thank you all in advance,
Bryan Tracy
If if you want to communicate with command and amp go to cgw and change year to 09 then you will be able to see all the modules.
Once you do that and you want am/fm reception ASAP for meantime you can take out sdar out of the ring and can use that fakra from comandonline and will have reception but it not be HD radio. Let me know how it goes.
For those who did this retrofit, how did you mount the later style roof antenna? Did you drill the roof panel or mount it elsewhere? I would really like to be able to receive the HD stations if possible.
A battery drain isn't too difficult to find and eliminate. Just don't pull blindly fuses as so many do and never diagnose the real reason but rather just the corresponding control module.
Daviko's harness has the antenna cable that plugs in the antenna plug that came out of the old AGW but then there is no connection to the HD Radio part. I think he doesn't know about the US systems and therefore leaves them out.
SDAR/HD Radio Receiver
I built two cables with Fakra connections on each end. Those then go to the new antenna amp in the C-Pillar
Edit: Confirmed the part numbers.... 211-440-09-32 from SDAR to antenna amplifier and 211-440-23-32 from NTG to antenna amplifier.
Is the second number you mentioned (NTG to amp) not part of Daviko’s cable harness? The one that plugs into the cable that came out of the AWG and connected to Daviko’s harness?
I’m sure it will never be 100% factory like, no matter how many times I compare my VIN with a VIN that has it from the factory.
The left hand side trunk panel needs to be replaced too but that is only available in black since it’s a facelift part. Not sure if I wanna have a two tone trunk now
I might just cut a hole for the fan in there.Last edited by Mackhack; Jun 15, 2020 at 12:04 PM.
I’m planning this on and off for well over a year now too.
