Do you let your AMG warm up on chilly morning?
Now that January has arrived, and temperatures are starting to fall. I'm just curious to know, how many of you actually let your E55 or E63, warm up in the morning before driving off.
I personally let my car run about 15-20 minutes, when the temperature is below 32 degrees. Besides I like getting into a warm car, with warm seats.
https://www.msn.com/en-us/autos/owne...cid=spartandhp
usually I just drive put it in drive and go, baby it until it gets up to temperature - the cold weather definitely makes the M113k have a little more juice
IMPORTANT COLD WEATHER INFORMATION
In order to achieve the low noise level of Lysholm superchargers, Lysholm specifies manufacturing procedures that call for minimal internal clearance. These precise tolerances however are not conducive to temperatures below 25° F. Therefore, storing the vehicle in a heated garage and/or employing the use of an engine block heater/aftermarket engine blanket is required when the vehicle is subjected to a "cold startup" in ambient temperatures below 25° F. Failure to comply with this may result in immediate supercharger failure and invalidate the
supercharger warranty.
SECTION 2
ENGINE STARTUP AND FUEL CONSIDERATIONS:
1. Never operate your engine at full throttle when the engine is cold. When starting the engine each day, allow plenty of time for the oil to reach full operating temperature before running above 2,500 RPM. Full supercharger operating temperature is generally achieved after the engine water temperature has been at the normal operating range for two or three minutes.
It should only take 2-3 seconds to get oil everywhere in the engine after starting it from completely cold. It takes many hours for that oil to drain fully back down into the crankcase and a thin film remains on all the bearings regardless. Once you have warmed up the engine there is no damage from start/stop engine features (on newer cars) or stopping for gas or an errand.
SECTION 2
I watched an engineer on Youtube who said that in fact keeping RPMs below 2500 is harmful, and that we had to use paddles to lock in the right gear manually, as the automatic will rush to the 7th gear. The reason he was giving was that the oil doesn't have enough pressure at lower RPMs and doesn't lubricate upper engine components properly. Now, folks in the comments to the video said that it applied to older cars as newer cars had electric oil pumps that ensure correct pressure regardless of RPMs. Does anyone know whether W211s have electric oil pumps?
questions I could ask, but I'll stop there. Like religion and law the written word is always open to individual interpretation.
Remember; if you run the clutched super charger (that MB designed for the car) it does not engage on start up, maybe that kind of answers your question
As for me, I believe SC manufacturer doctrine.
Modern synthetic lubricants are amazing animals. They flow readily at low temperatures, stick to lubricated parts after the engine has been shut down, keep the engine clean inside ect... All so much better then the Pennzoil my parents insisted on in every one of their engines when I was a kid that made for 1/2" of ick on every surface inside the engine over time and made for multiple failures as well.
You mention gasoline washing down the cylinder walls during cold running.... This is much less an issue in fuel injected cars using modern synthetic lubricants then was the case in the bad old days of carburators, garbage lubricants that didn't get changed ect.
At low ambient temperatures the oil will be thicker so more effort for the pump to deliver it. This is why we use a lubricant that does not turn gelatinous at low temps. Have you ever tried pouring 50 weight oil at ten degrees? A 5/20 weight oil pours and pumps easily by comparison. Oil at low temperatures is not going to lubricate as well as when hot + cold oil will collect water until brought up to high enough temperature to boil it off. Yes; water always finds it's way into the oil as perfect combustion makes CO2+H2O. Some combustion gasses always find their way past the rings. Short trips with oil never getting to 100C ensures that water never boils out. Not good. I have a neighbor whose work van gets started cold (ambient is 20-50f) driven five minutes and turned off. Every day. I got a call when he pulled a stick out of it and the stick had only.... *gasp! Milkshake on it! But not burning coolant. He now uses synthetic oils and changes it often enough.
I start mine up in the garage... Give it ten seconds and drive gently until coolant and oil temps are over 80C unless emergency then it gets short shifted at 3000 and I make a mental note to change oil sooner.
No electric oil pump in your E-55. Be thankful. Look to how it went for BMW with electric water pumps. Hmmmm.... I'm good with a chain driven mechanical pump.
Beware 'engineers on YouTube.' Not everything you see on the Internet is true.
Like this morning in Northern VA, it was cold out. And I typically let the car idle for 15 mins until the oil and engine coolant reaches it's operating temp.
I personally don't think that anything is wrong with letting things warm up, before driving off to work. I know that AMG fully tested these engines in adverse weather conditions.
But I'm old school, and I've done this for years with no ill effects. I just wondered how many others owners did the same thing.
I personally don't think that anything is wrong with letting things warm up, before driving off to work. I know that AMG fully test these engines in adverse weather conditions.
More on block heaters here:
