Has anyone tried the Brembo front rotors on an E55?
Old Apr 1, 2019 | 05:53 AM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
I just ordered these Brembo 09A81911 rotors from rockauto but I can't find any info on the forums about them. Seems the 2 piece E63 guys like them but wondering if anyone here has used them on an E55? I went with Akebono front pads to match these rotors per the multiple recommendations on the forum.
Are people reusing the factory brake hardware? Looks like a spring clip and new pins. I ordered a set of Centric parts for $10 but not sure on quality of these pieces.
Old Apr 1, 2019 | 10:30 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Honestly, these look like your standard OEM rotors. Keep in mind that Brembo is the OEM manufacturer for the calipers and rotors on all AMG's.
So these should work out just fine. I used Pagid rotors in the rear on my E63 without any issues. And of course, I have Brembo two-piece rotors up front.
Old Dec 24, 2020 | 10:49 AM
E55NOVA's Avatar
2006 E55 AMG
These aren't 2 piece but will that work with my 2006 E55? Rock Auto sells these for $99 each.
BREMBO 09A81911 {#2214211812, 2304210712} Premium UV Coated; Sold individually Info
Front
Old Dec 24, 2020 | 10:58 AM
Yuille36's Avatar
Front
I would say yes, but check compatibility to ensure it will fit your vehicle. My front rotors are Brembo, but the rears are Pagid with corrosion protection coating.
Old Dec 24, 2020 | 11:00 AM
E55NOVA's Avatar
2006 E55 AMG
Thanks, Rock Auto says it will fit the E55. These are much less (like $200 less) than the 2 piece Brembos. Wonder if there is any major difference.
Old Dec 24, 2020 | 11:08 AM
Yuille36's Avatar
The two piece Brembo rotors were designed for the E63, not the E55. I know that some E63 owners have gone with the one piece that are standard on the E55 and C63, do to their cheap cost. But I have seen any E55 with two piece rotors, honestly I think their diameter is larger.
Old Dec 24, 2020 | 11:12 AM
Yuille36's Avatar
Just did a little research and the E63 two piece rotors should fit the E55, as they are the same diameter. But I’ve never seen anyone mount them on a E55.
Old Dec 24, 2020 | 11:14 AM
E55NOVA's Avatar
2006 E55 AMG
Thanks for your input, that helps!
Old Dec 24, 2020 | 12:26 PM
bobgodd's Avatar
2004 E55
I'm using those Brembo one piece rotors, ordered from autohausaz.com
They fit perfectly fine on my E55.
https://www.autohausaz.com/pn/09A81911
Old Dec 28, 2020 | 06:13 PM
Windowguy's Avatar
2012 Audi S4 & 2008 E63 AMG
The 2 piece ones should be about 6 to 7 lbs lighter per rotor vs the 1 piece. I bought the 1 piece ones for my E63 because they are a lot cheaper here in Canada. I will do a brake job soon, just need to get the rear rotors. I think most people do not go with the 2 piece ones because of cost.
Rob.
Old Dec 28, 2020 | 06:21 PM
Yuille36's Avatar
Rob.
I don’t know if that is a true statement, the two piece rotors can be had for <$700 these days if you search hard enough!
Old Dec 28, 2020 | 06:26 PM
Windowguy's Avatar
I think I paid about $300 Cdn for the set for a set of Zimmerman 1 piece rotors when they were on sale at the parts place close to me. Rock Auto has great prices but the shipping and the exchange rate kills it for us Canadians.
Rob.
Old Dec 28, 2020 | 06:46 PM
Yuille36's Avatar
Understood, the exchange rate and shipping definitely raises the cost. Two years ago, I purchased a complete set, the two piece front rotors, rear rotors, brakes pads and wear sensors for $1000 US, after a lot of online searching. But your case is different.
Old Dec 29, 2020 | 09:18 AM
W21163's Avatar
2006 E55
I would get the 2 piece from FCP. It’s brembo plus it’s plug and play. Lastly you get a lifetime warranty on it !!
https://www.fcpeuro.com/products/bra...mbo-2194210212
the big difference with the 2 piece is it’s much lighter and it’s “unsprung weight” that you’re reducing plus it doesn’t warp as easily as a 1 piece
Old Dec 29, 2020 | 12:20 PM
Yuille36's Avatar
FCP Euro is by far the best option, as brakes are a consumable item.
Old Dec 30, 2020 | 03:23 AM
AMGPilot's Avatar
2004 E55
Yup
Run them in my daily driver
absolutely zero issues. Got them at RockAuto for $360/rotor
Old Dec 30, 2020 | 11:48 PM
sciroccor's Avatar
2007 e63 estate, 1998 ITB golf, ITE scirocco (sold to a collector in Japan)
i have some two piece rotors that have a lot of meat on them (grooves are still there). they click, though. they need to be rebuilt. anyone can have them. BUT, i am not shipping. come by and pick up them.
