E55 cranks but no start
No warning lights are on. Only code was a P20A2 - looks like it's a vacuum leak but that shouldn't cause it to not start. And if so it should start after clearing the code or disconnecting batter for a bit right? I tried that. I didn't see any bad hoses either.
I have replaced the CPS and the throttle body.
I plan to check the fuel pressure but did have fuel in the rail. I think I hear the pumps prime. With DAS I can't get the throttle body to move, I also don't see it move when trying to start, not sure if it should.
Anyone have any other ideas or maybe know the issue?
If I clear codes would a vacuum leak stop the car from starting?
MY '05 has one fuel pump relay and an air injection pump relay in the trunk.
MY '06 has two fuel pump relays and an air injection pump relay in the trunk.
a) First and second-generation filter/regulators work with first-generation fuel pumps.
b) Third-generation filter/regulator works with second-generation pumps. This configuration requires adapter cables for both the filter/regulator and the fuel pumps.
Internal to the fuel tank, the fuel line connections to the first and second-generation fuel pumps are different. External to the fuel tank, the electrical connections are different. With the second-generation pumps, don't be fooled that the stock harness connecter fits; without the adapter cable one of the pumps will run backwards.
https://mbworld.org/forums/w211-amg/...ml#post7719667
Read this thread as it provides a bit more detail:
https://mbworld.org/forums/w211-amg/...-warranty.html
This thread by BoostedAero explains the bad things that happen to your air/fuel ratio if the adapter cable is not installed (spoiler alert: fuel pressure drops from >5 Bar to ~3.2 Bar at full throttle and air/fuel mixture goes lean):
https://mbworld.org/forums/w211-amg/...ging-asap.html
The Amazon links to photos in his post are good; be sure to look at the last link in his first post. All because the dealer missed installing the adapter cable.
