Spring break Modding fun!!
Old May 9, 2019 | 10:46 PM
  #51
E55amg0220's Avatar
Veteran: Air Force
2003 Mercedes E55 AMG
Thanks for that info we are wking on the tune hit a few hiccups but we havent given up.
But in the meantime these are the fun things ive been doing ill let the pics speak for themselves and come back and explain when i have a lil extra time.
Old May 9, 2019 | 11:53 PM
  #52
boosted305's Avatar
broom
NIIIIIIIIICE!
Old May 11, 2019 | 07:21 AM
  #53
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
That pulley looks cool. What kind of harmonic dampener does it have.
Old May 11, 2019 | 10:57 AM
  #54
E55amg0220's Avatar
Veteran: Air Force
Its the innovative one that vrp sells with their amazing 3 pin and keyway kit. Definitely not for the faint of heart had go figure out an make my own removal tool and install tool but its all in and seems to be wking well so far. Only gone 2/3rds throttle and 4400 rpms an even then im making 2 psi more than i was with the stock pulley an 76mm upper. Heat is about the same maybe a bit less on iats.
Das_it16 is the one that hooked me up with this setup since he has a whipple now and hes been THE MAN when it come to guiding me to a good recipe for power an reliability. We did the math and according to vrps boost chart the old setup stock with 76mm upper is good to abour 14.1psi boost with headers. The new 187mm lower and stock 90mm upper should be round 15psi. At my current sea level 4500 ft i was seeing 8.5 to 9psi with old im now seeing 10.5psi and havent given it wot yet.
Also i can attest to the crank pulley giving more torque its like a whole different car its a complete animal.
Old May 20, 2019 | 11:12 AM
  #55
drothgeb's Avatar
Veteran: Navy
2005 E55
Any luck with the block off plate tune?
I'm not sure if you're interested in reaching out to him but DTK said he has been running welded shut bypass valves for years and can tune for it.
Old May 20, 2019 | 12:26 PM
  #56
E55amg0220's Avatar
Veteran: Air Force
Im waiting to hear back from jerry its been a lil bit and ive very leary bout anything from DTK becus of what ive heard about him but who knows im sure jerry will figure it out.
Ive been occupied with the current mods im up too i did my crank pulley an my new PNR trunk tank will be here tomorrow and my intercooler should be done soon as well. And then ill install my 80mm upper and jy 180mm lower which should add 2.5 more psi an stay nice and cool. Then ill be done for a lil while. But next thing ill be doing is E85 or E40 setup.
Old May 20, 2019 | 01:11 PM
  #57
drothgeb's Avatar
Veteran: Navy
2005 E55
Yeah, I get that. I've come across plenty of the threads with that kind of info too. I bought a couple things from him and have been happy with it though. Just an option to try though for us folks that really want this block off to work out if EC can't get it straightened out haha.
Old May 20, 2019 | 02:10 PM
  #58
E55amg0220's Avatar
Veteran: Air Force
Yeah im not going to wait forever so hopefully soon
Old May 20, 2019 | 02:16 PM
  #59
drothgeb's Avatar
Veteran: Navy
2005 E55
I know you've been busy, but have you had a chance to see where your mileage has steadied out at with the block off plate? I know you mentioned it earlier but you said you may have been a bit more aggressive with the throttle on that tank since just having the block off in.
Old May 20, 2019 | 02:31 PM
  #60
E55amg0220's Avatar
Veteran: Air Force
Yeah its only lost like 3 mpg
Old May 21, 2019 | 09:20 PM
  #61
E55amg0220's Avatar
Veteran: Air Force
And the modding continues this is what im up too at the moment, its mounted with poly mounts, and i have the hole made for the hoses to go through an keeps it away from moving parts and exhaust. Just putting it back together an routing the hoses, but taking a break for some potstickers.
Old May 21, 2019 | 09:37 PM
  #62
boosted305's Avatar
broom
Interesting, so you are going through the wheel well?
Old May 21, 2019 | 09:57 PM
  #63
E55amg0220's Avatar
Veteran: Air Force
Yep
Old May 21, 2019 | 09:58 PM
  #64
boosted305's Avatar
broom
Yep
Looking forward to seeing your routing path
Old May 21, 2019 | 11:03 PM
  #65
tlambert's Avatar
2005 E55 AMG
Interested in the routing path also
Old May 22, 2019 | 10:47 PM
  #66
E55amg0220's Avatar
Veteran: Air Force
You can see my IATs are 68.9 and my outside temp was 60
Well the install is done an wking good it does take time to do right and route it properly. But as you can see my IATs were round 68 to 72 and outside temp was 60 big improvement over before. I did a wot run from 1st through 3rd only saw 118 but what impressed me more wad within seconds it was down to low 70s, the recovery is very fast.
Old May 22, 2019 | 11:00 PM
  #67
boosted305's Avatar
broom
8-12 degrees over ambient with fast recovery sounds great, nice work!
Old May 22, 2019 | 11:02 PM
  #68
E55amg0220's Avatar
Veteran: Air Force
So far its doing great and dont even have my new custom single pass intercooler in yet still the stocker
Old May 22, 2019 | 11:04 PM
  #69
boosted305's Avatar
broom
Oh those results are with stock HE? Wow even better
Old May 22, 2019 | 11:07 PM
  #70
E55amg0220's Avatar
Veteran: Air Force
No i have a big VRP HE but the intercooler under the supercharger is stock but soon ill have a custom one single pass versus 3 way pass and 3/4 inlet an outlet with bigger tanks.
Old May 22, 2019 | 11:08 PM
  #71
drothgeb's Avatar
Veteran: Navy
2005 E55
Still stock size lines up to the intercooler or you have 1" ran everywhere or anything like thathat?
Stock intercooler, I highly doubt hes on stock hx.
Old May 22, 2019 | 11:24 PM
  #72
E55amg0220's Avatar
Veteran: Air Force
Its 3/4 line all the way to the front only line that is 5/8s is the one from the heat exchanger too the intercooler inlet. Since ill be changing these at some point soon i decided to just leave that line while im waitin
Old May 22, 2019 | 11:42 PM
  #73
boosted305's Avatar
broom
Ah, my mistake...Intercooler and HE often seem to be used interchangeably...
So custom intercooler eh? That definitely piques my curiosity...from what I've read, it's something that, although very important, seems to be an item that has never taken off in the aftermarket for some reason...
Old May 23, 2019 | 03:05 AM
  #74
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
ID of the stock Intercooler brass fitting is approx 1/2 inch , along with those aluminum lines in the front
Old May 23, 2019 | 09:25 AM
  #75
E55amg0220's Avatar
Veteran: Air Force
Yeah not ideal but its fine for a few weeks .... just wanted to see what difference the trunk tank made
