175mm crank 77mm s/c pulleys... opinions...
I used to have 04 E55AMG with 83mm s/c pulley large h/e and high flow pump, ecu/tcu tunes from eurocharged. I loved how impressive it was I was stupid enough to sell it...
Ive had this one 05 E55AMG for a few years now. Kept it stock. Did some maintenance and made it look better. But here is the dilemma.
My crank pulley just went...
And im thinking about making it nice preformancewise now...
Stock crank pulley diameter is 158mm
stock s/c pulley diameter is 91mm
total diameter is 249+/-mm
im thinking of buying 175mm crank + 77 (252mm total) mm s/c + larger h/e + high flow pump + ecu/tcu tunes
i would like opinions guys please... thank you all
77mm up top will be fine on its own.....or a 170mm down below will be fine on its own.....the combo is going to push a lot
This is semi-relevant....but mostly for reference:
https://mbworld.org/forums/w211-amg/...ey-matrix.html
you can see that you are climbing the chart into the heat zone quickly with the combo.
dont really want to go that deep into cooling. I wanted to keep it stock but this car becomes an addiction once u start going u dont stop
got wife and kids, i dont even race bmw’s anymore
) probably gona keep it stock for now, just gona get oem crank and save some money for the big project!! Thanks for your replies👍🏻One thing I don’t understand tho...
if u getting a biger crank and keeping stock s/c pulley, arent u stretching ur tentioner and belt?...
i have recently see a guy with stock s/c and 180mm crank and he had a bwk on it... what the thinkinh behind this?
With a stacked setup you want to use the largest upper possible, This reduces chance of slip.
Heres the modular crank if you wanted to take a look at at
https://vrpspeed.com/product/modcpkit/
Dont waste your money on buying two pulleys for basically the same ratio (such as a 168/83).
https://vrpspeed.com/product/70mm-supercharger-pulley/
The post that Funktron linked will show you that you can achieve very similar ratios with stacked pulleys as with downsized uppers
I'm curious how that modular pulley dampens harmonics. I don't see any rubber in it??
https://vrpspeed.com/product/76mm-supercharger-pulley/
Now im really upset for wasting money
trying to make things right
can i have opinions on 170/84 setup? Is it safe? 180 crank isnt im sure, 77 alone is too much for me so i want to balance it with 170-84 setup.
what u guys think? What cooling do i need?
larger he and ic pump be enough?
thank u all
thank u all
I had my car at the dealer for a recall and they said it needed a pulley due to wobbling. They wanted $1300 to do the job, so I ordered up a new pulley and installed it. The old one had a very small amount of wobble. The new one (fresh date code) was not perfect either. In hindsight, I would have left it alone had the dealer not said anything.
Old one didnt wobble at all. New one which looks and says oem could be not … im ordering a crank pin kit from moscor supercharge, they say it will take care of the issue
they recommend safe 172/84 setup with large he and ic pump, 2nd he and split cooling
Yes man i was broke so i had cheap stock pulley and i was good
now
i got another daily 1996 s500 🔥
So time to make e55 the right way
