LED High Beams
Old Jul 20, 2019 | 12:37 AM
Pmarino's Avatar
04 E55 AMG BLK/BLK(MyDD), 06 CLK 500 (wife's) 07 ML500, 2012 C300(son's)
LED High Beams
Obtain 2 BMW E39 5 Series H7 Car HID Xenon Bulb Conversion Adapter Holder Socket https://www.ebay.com/itm/For-BMW-E39...53.m2749.l2649
And a pair of JKCOVER LED H7
https://www.amazon.com/JKCOVER-Headlight-Advanced-Fanless-Conversion/dp/B074YH3X6G/ref=pd_rhf_ee_p_img_7?_encoding=UTF8&psc=1&refRID=6YZ51CJHN3H2J0MYS7GA https://www.amazon.com/JKCOVER-Headlight-Advanced-Fanless-Conversion/dp/B074YH3X6G/ref=pd_rhf_ee_p_img_7?_encoding=UTF8&psc=1&refRID=6YZ51CJHN3H2J0MYS7GA
Trim off the back
Drill them out with a 7/8" (22mm) bit.
Remove the H7 ring and insert the LEDs into the modified holder.
Place the H7 ring back on the LED
OEM halogen vs LED
Unplug the high beam from the factory harness. Remove the OEM H7 high beam holder and bulb from the reflector. Remove the halogen H7 bulb from the factory holder.
Plug in the LED into the OEM holder socket, put LED into reflector and plug the OEM holder back into the wiring harness
Old Jul 20, 2019 | 08:28 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Sorry I'm confused?? I just got pulled over for a low beam out. My car has stock halogens with an HID conversion on the low beams, that's why no warning on the dash. It already takes the H7 bulb but if I remember right it is 55 watts Does the converter box come with the bulbs, and will it give the right resistance to keep the dash happy?
Oh, and how do you like them?
Old Jul 20, 2019 | 09:18 AM
Pmarino's Avatar
Originally Posted by StarvingArtist
Sorry I'm confused?? Does the converter box come with the bulbs, and will it give the right resistance to keep the dash happy?Oh, and how do you like them?
Yes the LED's are canbus friendly for the high beams (have the proper resistance) My little blue high beam dash light turns on when the high beams are on. No flickering of the bulbs and no light out warning on the dash. I'm happy with them. I'll try to make a video at night. YMMV with them in the low beam projector, may have to get a canbus decoder https://www.ddmtuning.com/Products/L...ght-Decoder-H7
Old Jul 20, 2019 | 08:44 PM
Hey, thanks! I'll start ordering all this stuff tomorrow and see what kind of mess I can make
Old Jul 23, 2019 | 07:45 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Is the light source on the LED at the proper point for the reflector? Your pic shows it to be some distance from the focal point that the OEM halogen looks to be at. How's the light pattern?
Old Jul 23, 2019 | 08:59 PM
Pmarino's Avatar
Yeah the LED is a little further out, not too bad. It concentrates the light more on the road, rather than the tree tops. The reflector is not made for all the lumens, so the light pattern is going to be tweeked any way you do it. I was just looking to improve the halogen performance, which it does.
Old Jul 23, 2019 | 09:31 PM
Pmarino's Avatar
Here's a crappy iphone vid. It doesn't do the light' any justice. Really need a side by side comparison with the stock set-up.
Old Aug 3, 2019 | 09:09 AM
I got all the parts and started working on it yesterday. I think I ran into one of the few differences between E and CLS. My bulb sockets aren't even similar. Mine has a stainless steel clip that holds the bulb in. I will have to grind the hole bigger to make it work, but I can't find replacement clips in case it doesn't work out. If anyone wants to try this, I have 2 sets of those BMW sockets that are of no use to me.
Old Aug 3, 2019 | 10:13 AM
Pmarino's Avatar
Amazon Amazon
Old Aug 3, 2019 | 02:05 PM
vincheung's Avatar
S63, GLE580, BV250
i'll buy the sockets from you rather than have them go to waste. Shooting you a pm.
Old Aug 3, 2019 | 08:41 PM
Wish I had seen that earlier.
Old Aug 7, 2019 | 06:30 AM
Love my new LED brights. Instant on and much brighter than halogens. I upgraded my HID low beams while I was at it. Smaller, cooler looking igniters and new bulbs.
Sockets are in the mail Vincheung. There's not enough money involved here to bother with. My loss is your gain. I'm the kind of person who tries new ways of doing things constantly. Sometimes it pays off big time, sometimes it's an expensive lesson. This was neither.
Old Aug 7, 2019 | 01:05 PM
vincheung's Avatar
S63, GLE580, BV250
@starvingartist - Thanks, i'll pay it forward when I come across some spare parts.
Old Aug 7, 2019 | 01:07 PM
Naeblis's Avatar
2009 E63
You upgraded your lows to LEDs as well? Pics/vids welcome!
Old Aug 7, 2019 | 07:57 PM
No, just new HID's
Old Aug 8, 2019 | 12:22 AM
Naeblis's Avatar
2009 E63
Gotcha. What'd you upgrade to?
Old Aug 8, 2019 | 06:11 AM
Xtreme vision bright white, I think they are 5000k. A touch bluer than I prefer, but close enough. IIRC it's either 4300 or 4500 that looks pure white.
Thanks Pmarino for blazing the trail on this! My install wasn't anything like yours, I had to pull the whole front of the car apart to get the headlights out and fit everything on the bench. None of those clips were right, I ended up gluing the LED's in. Something I don't recommend, because I'll have to do it all over again when the LED's die. Hopefully far down the road from here.
