Vibration felt through the chassis at idle?
Symptoms:
Vibration felt through the seats and the doors at idle - in D,R, or N
Visible vibration of the engine
Once moving, not noticable
Notes:
Engine/transmission mounts replaced last week
Sparkplugs and air filters replaced 5k miles ago
Intake taken apart and checked, looked clear and tight
Idle stable at about 600rpm
Any ideas?? I'm wondering if it's just the new mounts? Or just normal for a big V8.
Cyrus
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
But your issue is when in D R or N
Is foot on brake in N?
Does not happen in P?
Put in park let engine idle open hood and look at engine... put hand on engine is it vibrating?
Do same but have someone in Driver seat - Have them recreate virbration in D, R & N.
Things it could be =
Bad motor mount or tranny mount (yeah you stated new but are they any good?)
Engine idle too low or miss
Flywheel cracked (doubt this but worth a check)
Torque convertor messed up and out of balance or fin missing or something.
Tranny input issues.
Applying Brakes is causing something to happen?? since I am guessing this occurs when stopped only
You can rule out anything after tranny since you say it happens in N.
Thanks again all for your help! I will continue to troubleshoot.
Also one or more bad fuel injectors can cause the problem.
A bad spark plug or coil as well.
Any error messages ?
Billet motor mounts as in solid? That will definitely transfer any and all vibration to the entire car. I am actually having a similar issue at idle in park. Perfectly smooth idle just feel a sort of vibration at idle and during gentle revs. I did put the car in drive and powerbraked it a tad and saw the engine almost lift kit of the engine bay, same thing when done in reverse on the passenger side. I suspect I have broken motor and tranny mounts and will be replacing them this week. I shall advise if this fixes it.
https://www.fcpeuro.com/products/mer...ercedes-538475
I had the car on the lift and confirmed my sway bar endlinks we're bad and one lower ball joint. I ordered all the parts to sort out the front end.
while the car was up inspected the flex disk and it looks good and wouldn't cause a vibration in park and at neutral anyway. Has to be engine mounts or a poorly balanced engine which would have grenaded by now...🤷🏻♂️
have the same problem.When the car is cold,Is making really shaky movements by idle,but the moment I drive it a little,the idle is getting smoother.I mean I can feel it by the end but is so minimum,like it should.
what I did to find the problem but failed miserably..
-motor mounts and trans mount (maybe I will change them again with the black series mounts)
-MAF Sensor
-timing chain was inspected but seems fine
-many oil changes(maybe something internal is failing but everything was clean)
-throttle inspected and cleaned
-not a single error code
if someone has a solution or an idea to help because I’m thinking to dissemble the motor apart and hope to find the problem at least.
-MAF Sensor
