Just had my M156 Head Bolts replaced!!
I've always said spend a few thousand now, or spend several thousand alter.
Those of you not familiar with the M156, these Head Bolts are female and due to their hollow head design didn't offer much material where it is needed. And with corrosion the top off the head would snap off, leading to engine coolant leaking into the combustion chamber.
And causing widespread damage.
The Valve Tappets looked pretty bad good for the mileage.
My tech said that these tappets, could have gone to 100K. But since your in there why not change them out.
And to be totally honest my slight valve ticking noise at start up is gone. the engine runs very quiet now.
The cam lobes showed very little wear for their mileage and age. Very surprising
The new Valve Tappets
And everything worked out fine.
I'm not saying that the new head bolts might not also fail in 10 or more years from now, as these bolts are always exposed to engine coolant, as they reside in the engines water jacket.
But to mitigate the corrosive effects of the coolant, do a coolant flush and change every two years. That is just my rationale.
I had five head bolts that looked really bad, out of the twenty. That was very concerning to me.
Everything checked out fine, been driving the car for a week now, and no issues.
I know that all to well, but the old saying goes, pay a little now, or pay a lot more later. Replace them before they fail, for peace of mind.
The procedure was to remove one head bolt at a time, and replace it with a new one, and torque it down to spec. Thereby keeping the clamping force on the heads sealed to the block.
They examined each head bolt that came out, along with the valve tappets and cam lobes for wear/cracks etc. There is a high level of skill needed to do this job, especially when it comes time to reinstalling the cams, and setting the timing.
They preliminary quote was for $2700 out the door, but that also included installing my custom carbon fiber interior trim. So all said and done, the price was $3795 and that also included New SLS valve tappets ($900) that I insisted upon over stock, and a coolant reservoir hose.
They said that the old valve tappets showed very little wear, and didn't need replacing and should last to 100K. But why not replace them, while your already in there. And the new tappets cleared up my light ticking sound inside the motor.
And replacing that coolant reservoir hose, eliminated my low coolant issue, which I assumed was due to a possible bad head bolt. They also pressure tested the cooling system and bore scoped each cylinder for coolant leaks.
They replaced each valve cover gasket, spark plug gaskets, cam adjuster housing gaskets as part of the procedure. So this wasn't the cheap fix after all, it always seem to cost more then expected.
But like I said before, it's better to pay a few thousand in this case, then to pay several thousand later down the road. Yes, it was a little costly, but I can sleep better knowing that my head bolts have been addressed.
And there is no longer an issue of if or when.
So if your just replacing the head bolts, your cost should be around $2000-2300 including parts and your shops labor rates. My parts were purchased from VRP and Mercedes Benz https://www.vrpspeed.com/product-cat...amg-m156-6-2l/
A break down of cost:
(2) Sets of head bolts $260 x 2 = $540
(2) Sets of Valve Cover Gasket $100
(32) SLS Valve Tappets $940
(1) Engine Coolant Reservoir Hose $80
Labor $1500
Total $3160 doesn't include installing my CF Interior Trim or Taxes
I also have a brand new set of SLS lifters for $500 if anyone else is interested in doing this job soon.
This second head bolt from the left looks suspicious, look just under the bolt head. It looks like it might be cracked.
Unfortunately, I don't have these bolts to examine closely. But it really doesn't matter, as they've all been replaced.
I've been taking my cars to Benz Elite Automotive for 10 years. My guys are certified Mercedes techs, and I absolutely trust their word without question.
The cams lobes were inspected very closely, they've even provided me with a video of it. They said and we both confirmed that the cam lobes showed no signs of wear.
As that was a big concern of mine, if they needed to be replaced. Because that's an additional $2400 expense.
It is possible that the wear marks were caused by dropping these valve tappets on top of each other. Regardless, I'm very happy with the outcome, and I'm not concerned in the slightest.
