What brand/weight differential fluid/gear oil are you using?
Old Oct 8, 2019 | 02:36 PM
nikehead1980's Avatar
2007 E63
Hi All!
I'm thinking it's about time to change out my differential fluid, I currently have 81k on my 2007 E63.
Was thinking of using Motul Gear300 Synthetic 75W90, would this be comparable to MB 85W90?
Any other recommendations? Did you have to replace the bolts and washers?
Thank you in advance!
Old Oct 8, 2019 | 02:53 PM
Dokus's Avatar
W211 e500 (Sold), w204 c180, w203 c180, w201 190e, W219 CLS 55
I think its the same oil as the 55 cars are using.
Castrol Syntrax 75w140 limited slip.
Replace crush washer if used, no need to replace bolt.
Old Oct 8, 2019 | 09:37 PM
coupesedan's Avatar
CLS55
Valvoline 75W140 FS Limited Slip. 10 bucks a quart at any local store.
Old Oct 9, 2019 | 06:51 PM
SilverE5588's Avatar
'15 E63S,'21 LCI M5
Sorry to hijack , does this stand for a 211 E55 as well ?
Old Oct 9, 2019 | 07:30 PM
coupesedan's Avatar
CLS55
That’s what I use in my CLS55. 75W140 with limited slip additive is specced for almost every modern AMG.
Old Oct 10, 2019 | 02:27 AM
cetialpha5's Avatar
I would just pick up the right fluid at the dealers. There's some other older threads where people mention using thicker fluid and getting worse gas mileage. The difference in price isn't that much, around $20+ a quart but you don't use that much so it shouldn't really matter.
Old Oct 10, 2019 | 02:10 PM
Dokus's Avatar
Which weight did you buy from mercedes?
Old Oct 12, 2019 | 12:48 AM
CDC55AMG's Avatar
CLS55AMG
I run Motul 75w-140 in my CLS55.
https://www.pelicanparts.com/More_In...=3736&DID=6528
Mercedes-Benz Differential Oil (Hypoid Oil) - SAE 75W-140 (MBZ Approval: 235.61) - (1 Liter) - Motul Gear Competition 105779
This fits your 2006 Mercedes-Benz CLS55 AMG Base Sedan
