Belt Squeal at startup and until engine warm
Any input is appreciated.
IMO; If you want to check pulleys, water pump, A/C , P/S ect... remove serp belt and rotate them by hand.
Belt noises can be diagnosed with a spray bottle of water. With the engine running and the sound audible, lightly mist the grooved side of the belt with water. If the noise disappears or lessens, but then shortly returns, the problem is probably a misaligned pulley. If the noise immediately increases after the belt is misted, the belt is slipping.
https://dayco.com.au/pageBANK/docume...bottletest.pdf
Fascinating
But I'm still pulling the belt and checking everything by hand
