Over revving and stuck in limp mode )
For a long time ago i testdrove a friends sl500 with similar problem as you describe. My memory tells me it where a bad valve body solenoid.
I'm expecting you'll have the implausible gear ratio fault from your trans oil being too low or high. You can use basic obd 2 scanner like elm327 and torque app.
Put the stock tune on and see if it goes away if you cant pull codes, like new55 said. I've had some tunes mess up my cars rev limiter before and the car drops gears to protect itself. If your tune is the problem I reccomend eurocharged if your tuner cant fix.w
If you going to buy a scanner on the cheap i recommend icarsoft MBII. You will be able to read all codes and live data, no programming tough.
Here is how you use it
https://youtu.be/OcQPXRAmAmw
https://www.mercedesmedic.com/how-to-check-automatic-tranmission-fluid-level-in-mercedes-benz/
Any feedback on them?
