Cluster is blank and other issues
I ran DAS on it and got an "-i-" error for the instrument cluster. It won't communicate with it at all. Usually DAS shows an -F- for things it doesn't like.
Any ideas where to start looking? I have found some other people with this issue in the past and it seems like having the batteries disconnected for a while would end up fixing the problem. I have had the car for 5 years now and have never seen this one yet.
Other issues I have noticed as of now:
lowbeams are on no matter what.
supercharger did not engage on a short trip yesterday
Did you go into the controller with the "i" and check for codes or events?
Low beams.... You did not mention if they are HID or halogen?
http://support.rollsbattery.com/supp...tery-sulfation
bi xenon headlamps.
I couldn’t even read the events for the cluster. It just will not acknowledge it when I try to dig into.
. Doesn't sound like the car is driven much that is why I'm suspicious of the batteries. From the link I posted " When hard sulfate is present, the battery shows a false voltage, higher than it's true voltage, fooling the voltage regulator into thinking that the battery is fully charged. This causes the charger to prematurely lower it's current output, leaving the battery discharged".I assume you gone through the fuses.
When did the low beams get stuck "on" before or after the cluster situation?
With all the rain the east cost has gotten I'd also check for water intrusion.
Its my wife's car and she spent a bunch of time cleaning out pine needles and leaves from around the hood area. I absolutely agree its a water ingress issue, but I'm not sure where. Maybe sunroof drains? I really wish it was something obvious, all fuse locations look dry.
I really appreciate the help and battery link!
Sun roof will be front A-pillars and overhead controls as well as rear foot wells.
