Bouncy BC Coil Overs
I set the "preload" the way the instructions advised.
Does anyone have any suggestions before I go back to air suspension?
thank you.
If you have the suspension in full droop when you tighten the bushings, it will preload the rubber when you put it on the ground and will give you a very bouncy ride and could kill your bushings in short order if you don't fix it.
essentially your shock height needs to match with the spring height to allow for your shock to operate in the correct stroke region.
Thanks for all the input.
