2005 has a new speedo
The 2005 cars have a 200 mph speedo and a new mesh vent over the center vents while the old car had a 160 mph speedo and a plastic slat style vent on the upper dash.
Just some info for fun...
Originally Posted by akbro93704
also, a redline indicator was added to the tach...
It just looks better with the red hash marks. Small things that make a big difference!
1 Post
4 wheels
Will we be able to retrofit this onto our existing clusters, or do we have to get new cluster? sure would love to have a redline, just adds that sense of sportiness IMHO.
Originally Posted by norb
The 05's are out already? Damn that's early.
It is early for the 2005's but they have been out for abouy 2 weeks I think. Saw my first E55 2005 in person yesterday and it is not much different. Also saw a 2005 C55 and the 2005 CL65 (talk about added mark up...WOW).
Little things but still changes none the less.
Originally Posted by CynCarvin32
A new cluster is in excess of 1k I would guess and it has to be matched to the miles on the car etc.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Your right, with a new speedo cluster, you need to program the current mileage into it. I'm not sure you can even do that rhough DAS. I think you need to order it from MBUSA and then they code the mileage into the cluster.
Upon installation, the cluster then needs to be coded to match with the EIS via DAS.
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
-s-
Originally Posted by scorchie
The procedure to follow is in DAS, and it varies by model. But I believe with the W211, the DAS will notice a new cluster installed and ask if the mileage should be copied to the new cluster. Then it does it and you're through.
-s-
-s-
Super Moderator
Originally Posted by atssystems.com
..and if you pick no..??
I don't think the car will start without the cluster and EIS agreeing.
E55, F550, S600 Ducati 999
Then you got problems. ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
This is how you can "wind back" the odometer reading on the car. I was recently offered, but declined this service.
Originally Posted by RedBaron
What's the point of having a redline when the computer won't let you go beyond redline anyway???
Computer usually lets you go a couple hundred RPM beyond redline.
-s-
Mercedes-Benz
the 2005 cars must have the M mode (full manual control), then I could see a use for a redline mark. Otherwise it doesn't really matter, the auto trans/computer controls where the engine revs are.
