What HP should I see with these mods?
Old 05-07-2020, 08:11 PM
lost27's Avatar
CLS55 AMG
Originally Posted by oneslow55
If your looking for big lower gains,you got the wrong car..530 whp on a good day ,this what these cars make pushed hard on fbo setups ..
I'm perfectly happy with around 530 . Don't feel like I need any more than that.
Old 05-07-2020, 09:03 PM
manon407's Avatar
2004 E55K
When I initially got the car, I was taking off the intake, and a rubber gasket/ring might have came off of the inside of the intake Y tube that connects to the TB. I never bothered to replace it because I thought it was from some other thing that the previous owner screwed up (it looks like they either half-assed, or didn't know how to do a lot of the work on the car). Here is a video of how my intake sits on my throttle body. Should it have that much play, or should it feel solid? It feels like there is a little gap where I stick my finger at the end of the clip, barely big enough for me to feel. If that's the issue, then is there a part number for the part, and would I need to Re-tune once I fix it, since I tuned it when it was unhealthy?
https://www.youtube.com/watch?v=Jmfi...ature=youtu.be
Also, with these mods How much psi SHOULD I be seeing?
Old 05-07-2020, 09:34 PM
coupesedan's Avatar
CLS55
Agreed.
Everybody and their grandma can pull football fields on a 55k. These cars are a decade past their prime, most of us shouldn’t try to play out of our league.
Old 05-07-2020, 10:28 PM
tw2
tw2's Avatar
2005 E55 AMG, 1991 MR2
Agreed. I am at 490whp with an 83mm pulley. No plans for any more mods. This car is for torque, ideally need some turbo's and a more modern engine design (quad cams, 4 valves, variable valve lift, duration and timing are all now possible) for easier power.
Quick Reply: What HP should I see with these mods?
