Different Coolant for split system?
In a few days, I'll be receiving a Eurocharged ECU tune, 76mm pulley, belt wrap kit and split cooling. I was going to get the upgraded HE also, but I was told that installing it in the SL55 is way harder than the E55. I never track this car. I just drive through the Sierra Nevada mountains and up HWY 1 for fun. I'm going to see how well the split system works and hope I don't have to go full on with cooling upgrades. I get that the hose clips will make me angry, but I'm really wondering about the coolant. Should I use something different? I've read that mostly distilled water with Water Wetter will do wonders, but I keep reading that from general "cooling" posts, mostly NA engines.
Any input would be appreciated.
Several years ago, I found that I couldn't pull away from a Chevy Cruz on the highway during a 110 degree day. Even the driver of the Chevy looked over at me like I was pressing the wrong pedal. I replaced the bosch pump the next day.
I'm going to put together a NorCal (Sacramento area) AMG drive soon. I have to make sure I can keep up with the newer participants.
However for sure you wont want to do split cooling. 200 degrees engine coolant will get in the mix of the Intake charge cooling circuit.
