82mm TB Hiccup/Lean Rabbit Hole and my Fix
On the plus side it's got some really nice features. The ability to log, and overlay any of the data collected from any of the inputs over top of the fuel or spark tables. So you can overlay say AFR and it will directly overlay your logged data into the adjustment table making it super easy to fine tune fuel. Its got two different PWM outputs, can control methonal pump, or you can set up rules to trigger lights under what ever circumstances you want.
Anyways, I'll do a separate write up in a bit with a wiring diagram probably and some info on the hiccups I ran into, hopefully some data on how well the tuning is working for me haha
Yeah, real bummer. I E-Mailed their US and Polish(home) tech support. The US support got back to me quickly but seemed very confused by the question, first telling me it wasn't necessary to see what actual ignition timing was and started talking about a different product, then when I clarified that they were talking about the wrong product, they responded and started talking about dangerous ignition voltages as if I was wanting to connect to a damn spark plug wire. I think the brains of the operation are in Poland and the "EcumasterUSA" folks are just a sales team. The Poland support email has not responded back. Pretty sure I know the answer though. I did pull one of the knock sensors into an aux input and I'll see if I can get anything good from there. I know there are a few threads on here that talk about how noisy and difficult the sensors are, with no usable data. But the DET has a few things as well as frequency input/filtering that I can play with to see if I can make sense of anything out of the sensor. But for now it's back to watching toque timing logs for knock
On a side note what do you run for fuel??
Timing was easy to see it works! Did a run, logged timing with torque, set all timing cells to -2 degrees, watched torque again and saw 2 degrees less timing across the board haha. So that's good news.
I'd like to fine tune timing as much as I can, knock limited and get AFR squared away around 11.5 across the board but without a good way to see if i have knock the timing is a bit of a crap shoot.
I can't tell you how many times I have had transmissions and valve body's out to tweak and adjust to get it just right. !!! Labor of love with this stuff I guess !
Got a great new lead on a way to monitor knock though. KnocksenseMS ties into existing knock sensor or sensors, runs an LED light, and produces a 0-5v analog knock detection output. I'm waiting on a response from the seller but will pull the trigger as soon as he sends paypal info haha. Fingers crossed he still makes them. http://www.viatrack.ca/
https://youtu.be/g4Z_M_8cHmA
Start car let idle drop before driving
Cruise from 70-90 MPH with a pull once warmed up to get some boost
Cruise from 80-90 MPH on south I35 into a head wind
Felt first hiccup and saw STFTs stay high (highlighted in orange in log sheet)
Continued south until I found a safe place to pull over
Let car idle for a few minutes noticing the car having the rough idle like it was trying to stay in idle
Turned car off, removed key, opened door and waited a few minutes
Restarted car and headed back to Austin on I35 north
Cruising at 80-90mph felt slight hiccup an saw check engine light come one
That stretch of road and driving conditions will trigger the hiccup almost 100% of the time (depending on traffic conditions as I need to stay at 80+ for a while without slowing down). Those speeds and terrain might be why some folks do not experience a hiccup, it also seems like a majority of the conversations have moved to facebook which kinda sucks for those of us without it.
I *almost* wonder if there is a ram air effect at those speeds and with the 82mm throttlebody that is contributing to the hiccup but that is just speculation. At this point since I've tried 3 used 82mm throttlebodies I've been recommended to try a BRAND NEW 82 to start with a known good working throttlebody. If you are on the facebook groups you might pose the question there to see if folks have an issue.
With as many 90mm throttlebodies being promoted around here I'm surprised that none of those folks have experienced the hiccup.
But, I verified it's not related to the stock intake/potential ram air type deal by switching the factory intake with the green mushroom filter straight off the throttle body. Same issue.
