DIY: ECUMaster Digital ECU Tuner3 Piggyback
Do we know if they were able to update that 6 degrees per unit of retard? That's a bit much. Some might want to retard in boost even half a degree per lb of boost. Also the timing advance was confirmed to work? I'm wanting to hear others updates regarding this product.
The DET3 allows you to control timing by tricking the engine into thinking the crank shaft in in a slightly different position. I'm not sure why in their programing you can only do a full tooth (6*) for retarding timing but it is what it is. I would get a conservative tune with like low teens timing then use the DET to add the remaining timing you need so that you can control it on individual degrees however you like.
