Head gasket Issue (but not head bolts)
A couple days later (had it parked) I put in a gallon of 50-50 mix of the appropriate blue coolant. I drove it 10 minutes and checked the fluid level. I found the dreaded milkshake coolant instead. Drove it back home (downhill) and parked it. The car never overheated at any point during this episode. There was no visible coolant in the oil filler area (cap) or the dipstick. The car never ran rough or exhibited any other issues. Had it towed to my indy a few days later and let him look at it.
My indy pressure tested and found a leak in the plastic radiator end tank, so we went ahead and started that project and this may be why I was losing coolant. He found cloudy coolant in the radiator and upper and lower hoses. Not so much in the block though. Still, my guess is that this is a head gasket failure, but is that likely given what happened? The car never got that hot, the temp gauge only got slightly above halfway and the auxiliary fan was on when I had the boil-over, is that enough to ruin the head gasket? The only other oil/water mixing potential would be the transmission cooler I am told, but my milky coolant is grayish-green, not the brown clay color tranny fluid would cause. The oil cooler is separate from the radiator and coolant so no potential to mix there, right?.
We are going to test the coolant for exhaust gas, which will be definitive for the head gasket. Assuming that is what it is, would the oily coolant have damaged anything else? The indy said the radiator hoses get soft when exposed to oil, what about any other seals? I already had a new rear main seal replaced under warranty, would that be compromised? I ask because a head gasket job is one thing, but if there is a lot of other stuff that is ruined it might be cost-prohibitive to repair. I am seriously considering Steel Seal head gasket sealer (what have I got to lose?) but I might not do that if it is “only” a head gasket. I might use it anyway, as I guess I could still do the head gasket repair if the Steel Seal doesn’t work.
My question is: Am I missing anything here? Could it not be a head gasket? Is there something really bad about using the Steel Seal other than the mickey mouse aspect of it? I’d have to dig a little deeper than I want to right now to swing the head gasket repair, but it is cheaper than buying another car is how I look at it. Still,
I am not going to throw 10k at it if there’s more to worry about here. Last, did my simple oversight with the radiator cap being left off cause all this? (Please say no).
Thanks for any insight!
Coolant color
If the engine coolant hasn't mixed with your engine oil, then it's isolated to just the coolant system. This would indicate that you don't have a head gasket issue. Just contamination due to a open reservoir cap.
This will give you a better idea of what's going on. As you stated, there isn't any coolant mixing with the engine oil, so that rules out blown head gasket, or even broken head bolt. Could it be a problem with mixing different engine coolants together.
Possibly an adverse reaction, of two different chemicals. As Mercedes has their coolant, then there's everyone else's. I think that this could be a strong possibility. As I can't think of anything else at the moment.
Maybe a seal in the front cover leaking ?? into the oil??
Hopefully not.
I took the car and drove it a couple days, maybe 40 miles total. Heat worked, engine ran just fine and no overheat or hint of overheat. I did notice the shift from 2-3 was slippy under normal acceleration, and became a bad stumble under harder acceleration as if traction control interfered. This did not happen in M mode though. Was thinking it was the transmission learning my driving again after essentially sitting for a week. I took it in this morning to have a look. The coolant in the reservoir was a brown color before I drove it (and it was low, but no top off coolant message). When I drove 10-15 minutes to the shop, he took the cap off and it boiled over briefly before the coolant was pulled back into the system. He felt that this was not normal since the engine was not hot. The coolant that came out was perfectly blue in color, for whatever that's worth. I am having him check the transmission fluid level and condition, but it seems to me this bubbling is coming from somewhere. I am not sure how much burping has to be done when the block is drained, but perhaps it is still air in the system?
Also this devices will alert you if there is a leak, as the suction will fail.
