Cannot Get Rid of the Red Visit Workshop light (the one with the battery image)
Old Sep 21, 2020 | 10:46 PM
grizzly67's Avatar
2006 E55 AMG
2006 E55 AMG
Non-technical Newbie struggling with the red "Visit Workshop" battery light.
Have replaced the main battery in the rear.
Have replaced the 2nd battery under the hood.
Both show >12.5V when out of car.
When car is running, reading between rear main battery posts is near 14V.
I assume this eliminates the batteries and alternator as the issue?
No codes via reader, just the ugly red "Visit Workshop" light.
No noticeable performance, electrical or other issues.
Any ideas? What should I try next?
Old Sep 21, 2020 | 11:00 PM
grizzly67's Avatar
2006 E55 AMG
Maybe I should try this next?
https://mbworld.org/forums/w211-amg/...lternator.html
Old Sep 22, 2020 | 01:19 PM
machild's Avatar
2006 CLS55 AMG, 2005 SLK 350 AMG
Originally Posted by grizzly67
2006 E55 AMG
With your reading of nearly 14volts at the battery the alternator and its voltage regulator are doing its job. If you are using a simple OBD II scan reader that is not going to tell you much about your car. Those scanners will only report engine operating faults - not any of the faluts from the many, many other computers throughout the car. You likely have an issue with the Battery Control Module (one of the many computers I referred to). Was the Red dash light showing before you replaced the two batteries?
Old Sep 23, 2020 | 07:39 PM
grizzly67's Avatar
2006 E55 AMG
--- moved to reply ---
Last edited by grizzly67; Sep 23, 2020 at 07:42 PM. Reason: --- moved to reply ---
Old Sep 23, 2020 | 07:41 PM
grizzly67's Avatar
2006 E55 AMG
The red light appeared after the battery went completely dead. Put in 2 new batteries (front and rear) and red light remains. Do you know if that "Visit Workshop" light clears itself once the problem is fixed or does it stay on until cleared? For all I know, there is no longer a problem and the light is there from the previous event. I now have the regulator part 003-154-65-06 that's a simple change on the alternator, but I am reluctant to attack that as my hunch is the alternator is actually working. I will go with your advice and get a shop with an advanced scanner to read it but this is a logistic challenge too as the vehicle needs to be re-insured to drive it there (already stored for the winter).
Old Sep 24, 2020 | 10:57 AM
machild's Avatar
I suspect that the fault just needs to be cleared. I have not had that specific fault so I don't have any direct experience with it. Maybe someone else can share some light on this? Have you done a thorough search of the site to see if the issue does remain after correcting the low battery problem?
Old Sep 24, 2020 | 04:38 PM
Fantomas's Avatar
2006 ML350, 2005 C55, 2004 E55
What he said, you need a decent scan tool to read the Auxilary Battery module and reset that code.
Old Sep 24, 2020 | 04:42 PM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I'll pile on because it's related - does anyone run AGM for the main battery and if so, is there anything to code for that? And can that be done with something like the iCarsoft?
