Transmission trouble NEED HELP!!!!
Purchase the ATSG 722.6 Transmission Manual while your car is being repaired. Study it. It will take several days to do so.
Find a copy of WIS, purchase, and study the details of the shifter module in the center console. Study it. It will take several more days to do so.
So...possibilities are:
-shifter module failure due to old age or contamination
-shift linkage bushing failure due to old age or the lock nut loosened
-internal 722.6 failure due to old age and wear
-possible brake switch failure
If you received a "hard" code for transmission failure, the transmission will remain in limp mode until the error codes are cleared using STAR. So, clear codes, read the ATSG manual, ensure the shift linkage is set correctly, verify the brake switch using STAR to ensure it is signaling the transmission you applied the brake (or just replace if you don't mind throwing parts and money at the car). Next read the transmission brake and clutch pack values plus fill times, etc, etc.
You've put it in Reverse and once it shows in Neutral and the other time in Park. Once you put it in First (I'm thinking Drive but in manual mode) and it's in Neutral. So, I lean towards the shifter module but those are not cheap so I would troubleshoot more prior to throwing parts and money at the car.
The N2 and N3 speed sensors together act as the Input Shaft Speed Sensor (Figure 8). The N3 speed sensor (solid black) is the most forward speed sensor on the conductor plate. This sensor reads the rotation of the K1 clutch drum inside the transmission (Figure 9). This drum has the front planetary sun gear attached to it and it lugs into the B1 clutch on the pump. What this means is that whenever the B1 clutch is applied it holds this drum stationary. This occurs in Park, Reverse Standard Mode, 1st and 5th gear. In these ranges the N3 rpm reading will be 0.
The N2 is the next sensor back on the conductor plate (silver top) and reads the rotation of the front planetary carrier assembly. This gets driven by the front ring gear attached to the K2 clutch drum and input shaft. This means that anytime the input shaft is in rotation so is the front planetary carrier assembly. The N2 will provide and rpm reading in park and neutral, and all forward and reverse gear movement but will read 0 rpms when in gear with the brakes applied.
FIGURES 7-9
As a side note, the N2 rpm reading in 1st and 5th gear will not be actual input shaft rpm. This is due to the carrier being driven by the input shaft through the internal ring gear, which will slightly reduce the speed of the carrier.
But when the K1 clutch applies, it locks the sun gear to the carrier forcing the entire front planetary assembly to rotate at actual input shaft speed. This occurs in 2nd, 3rd and 4th gears and when it does, both the N2 and N3 rpm sensor readings are exactly the same (if the transmission is functioning correctly).
Chrysler has offered a speed/calculation chart that is provided for you in Figure 10 along with the following explanation: Since the N3 is inoperative in reverse standard mode, 1st and 5th gears, it appears that the N3 sensor is redundant and provides no additional information. However, the TCM needs to know input shaft speed. Since the N2 sensor is not directly tied to the Input Shaft, the N3 sensor is required to inform the TCM to divide the N2 value by 0.6081 or 1.0000 to calculate actual input shaft speed.
The chart in Figure 10 confirms the normal operation of the speed sensors, the N3 sensor being at 0 in reverse (S), 1st and 5th gears while the N2 is providing an rpm reading. Then both are the same in 2nd, 3rd, and 4th.
This statement #Chrysler provides in accompaniment with this chart reveals some computer math (strategy). The computer is programmed to divide the 0.6081 value into the N2 rpm reading to obtain a “true” Input Shaft speed in rpm. Once this is calculated, the Output Speed RPM is then used to be divided into the Input Speed to calculate gear ratio.
FIGURES 10-13
Figure 11 is a first gear screen capture at 10mph of a 2008 Jeep Grand Cherokee which provides the following data:
Turbine (Input) Speed: 1,499 rpm
Input Speed Sensor 1 (N2): 912 rpm
Input Speed Sensor 2 (N3): 0 rpm
Output Speed: 421 rpm
The N2 rpm of 912 is divided by the 0.6081 value equating into an ISS rpm speed of 1499.7533. Round that off to 1500 and divide the output speed rpm reading (421) into this number to calculate the current gear ratio which = 3.56 (first gear ratio).
Read about the speed sensors, N2, N3. Also, put it into drive, at idle, with the brakes on, and take another screen shot. Post it up.
You will need to get it up on 4 jack stands as high as possible.
I don’t know if the trans is different from a SC M113k vs a N/A M113. I’m sure someone here knows the answer and that might help you find a trans easier.
Thank you all for your help! I really appricate it.
