2009 W211 E63 M156 oil leak
As one that has had a upper oil pan leak, it is an immense job, I wrote a thread about it on here. Anyway, it is not cheap, and the entire suspension and subframe need to come out, including the steering rack. It’s a labor intensive job.
The CPS can be replaced, but if you not having issue with it, I would leave it, as these aren’t a high failure item.
The following 2 users liked this post by Yuille36:
MbBiturboFan (12-29-2020),
PNW_E63_AMG (01-11-2023)
UPDATE: about 8000 miles since my last post, and the car has no leaks. Rear main seal was replaced around 136k miles, car now at 144k miles.
For anyone in the future experiencing a large oil leak from near the engine/transmission area, it's probably the rear main seal. Have it replaced at an indy for around $800, which is what it cost me for my 2009 W211 E63.
The following 2 users liked this post by MbBiturboFan:
PNW_E63_AMG (01-11-2023),
Saurabh914 (06-02-2021)
looks like you may have a few leaks. when i had my car serviced, i had a bunch of things changed including resealing of mid oil pan and lower oil pan as well as front timing covers. my lower most oil pan cover seems to be leaking once again. rear main seal looks fine and hasn't been updated to my knowledge on my vehicle.
I sure wish I busted the move when I took of my my Heads to be rebuilt to replace the Crank Drive Chain and slide rails as well as the Oil Cooler Chain its slide rails, but at the time, I didn’t want to mess with the Radiator! Ironically, after finishing the front, and then the entire rear end suspension, bushings, hubs, Rear Main Seal, 3.06 Gears and LSD, I went to start it up and noticed a radiator leak! So I only then replaced it and again had access, even already removed/replaced the A/C Compressor, the entire front bumper, as well as the PS Pump, so that would have only required me to remove/replace the Water Pump, Alternator and I would have been golden, but alas I didn’t! The main issue was determining how to remove that damn Crank Pulley? What a missed opportunity! I do have those replacement parts in a box for “next time”!
Now to my question, you reference the ingenuity of AMG having the “Access Port” that is seemingly “Oil related” on the back side of the Timing Cover? What is it by the way? It looks to be located between the AC Compressor and the Crankshaft?
hi guys, i have a big oil leak. i had both oil pan gaskets (or RTV) replaced per WIS/ASRA. still leaks. dealer says my intake manifold is leaking. this sounds incorrect as i would expect a check engine light if the mixture was wrong. but, i watch a video, the gut pulls off the intake manifold and there is oil in it. i don't really get why there is oil there. i don't see any oil pathways in the manifold. maybe it goes through the throttle bodies? even so, the car doesn't blow smoke and is still very quick. A/F must be OK. any ideas? perhaps the leak is just a valve cover gasket? any ideas? thank you!!!
SPONSOR
11 E550, 16 AMG GTS, 13 S550
do me a favor and replace the PCV in the back of the engine too.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Service Manager/Owner
Amsoil Independent Dealer #7236674
thanks ChrisHimself,
it's leaking like a quart every 400 miles or so. lots of oil left in my garage and even when i just back in, there're a few milliliters. unsightly. but, at that rate, it's not a mist. but maybe it's just pcv? but this is a real leak. i'd be willing to bet that it's not the intake manifold but is really a cracked valve cover. when i had the head bolts changed, the mechanic did crack one of them. we just put it back together with JB weld. maybe it gave up?
#32
SPONSOR
i couldn't tell you what the advantage is, I can only guess that it deals with warpage/heat better than the thin metal guys we're used to.
__________________
sciroccor (06-15-2023)
#33
NO! i didn't know there were new valve covers. i'll look for them. mine are original and very fragile. i think that they are Mg. they seemed much more brittle than Al. thanks!!!
#34
SPONSOR
__________________
