Bypass Delete M113k
I think that's normal, mine does that too. You can see the boost drop around 0.1bar nearing 6k rpm
https://www.youtube.com/watch?v=gjrfXAXISFE
2005 CLS55 AMG W219 C219
His car is not stock. He has midsize headers, milled down pulley (87 or 83mm), other cams, cooling upgrades
UncleBenz55 (01-30-2023)
W211 E220, W211 E55, W219 CLS 500
Enginewise i have mid tube headers, no primary cats, stock secondary cats and a stock W211 E63 exhaust. Supercharger has no bypass valve, Kleemann camshafts and a 80mm throttlebody. For cooling i use a Pierburg CWA100 pump, W220 S55, W213 E63 and W176 A45 heat exchanger. During cooler ambient temps (8 degrees Celcius) i logged the car at 7,1s. TCU is also not stock. With all mods the car was custom tuned on a dyno. It came out at 570hp/ 740Nm @ crank last summer.
nd-photo.nl (01-30-2023)
#32
Can do it without install blow off valve?
Block off your Bypass Valve with these Stainless Steel VRP Plates.
We couldn't stand seeing people paying $85+ for a literal Brick That was a horrible way to Delete the Bypass.
Other companies sell bypass “relocation kits” and call them delete kits, With those you'll need to find a place in your engine bay, to leave your bypass valve plugged in!
With our plate you leave the bypass in place and simply remove the factory butterfly. ECU is Happy and you dont have to stick your Bypass in your cabin air filter compartment.
You will need (2) lower gaskets to run this plate (We do offer a gasket kit with both lowers and the upper seal for $18)
https://www.vrpspeed.com/product/bypass-delete/
Is there any tuning to make it work normaly with manual transmission???
#33
Proper set up Whipples run 5-6s 100-200kkph iirc. My car is not really stock, only my boost is pretty much stock. I went with another appoach than most people and kept the boost pretty much stock (0.7-0.8 bar) stock pulley milled down from 91mm to 88mm, but reduced some weight on the car where i could. I had the interior apart and removed excess wiring harnesses and old japanese ecus, from the Teleaid system etc, i didn't need anymore, which was about 8kg. My suspension is lighter than the airmatic, and my seats are also lighter than the stock seats. I also removed the secondary airpump and some other stuff, which all adds up.
76mm sc pulley with BWK
Long Tube Headers
And Primary XL Hx and secondary HX
i did a boost test with torque pro i was hiting 12.57 psi 3rd gear and 13psi 4th gear
100-200 8.41s 200-250 8.53
its 20 degre celsius outside and my sea level its 18m so whats going on with my car tuned by Vtech but not duno tuned its my boost okay cuz the tuner its saying you have low boost
#37
bro i have an e55amg 2005
Long Tube Headers
Long Tube Headers
I had same issues and couldn’t understand where is my boost.
Switched to 76mm STEAL pulley and now log 15.5-16.5 psi
