W211 AMG E63 VS BLIZZARD - Snow Storm Night Drive
FULL VIDEO HERE:
Instead drive my X5M, and it has the same tires as my E63. It is much better for putting the power down with its All-Wheel Drive.
x5m is another beast.
When the temps are higher than that, the cars oil is running hot, for example a 5 hour long road trip running AC in 98 degree weather with high humidity.
So in my case both the primary and secondary oil coolers, were blocked by snow and ice and I could see the temps risen in the instrument cluster, so I knew I had to pull over and clear them. And sure enough the temps returned to normal.
If you didn’t know, the E63 oil temperature gauge will flash until the car reaches normal operating temperatures at 81 degrees Celsius. That is when the oil temp gauge stops flashing.
