New Rear Bags, blood Transfusion and HVAC Blower Motor/Resistor
Old May 9, 2021 | 08:43 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Originally Posted by equitiesguy
Blower motor is a 5 minute job, literally. Couple of bolts on the cover, one wire. Simplest design I've ever seen.
Arnott rear springs (AMG version) ride better than my stock AMG springs.
I disagree, it takes only than a simple 5 minutes. As it’s a pain in the *** getting under the dash.
Old May 9, 2021 | 12:28 PM
equitiesguy's Avatar
Mercedes CLS 55 AMG
Only if you're fat, and not trim.
Old May 9, 2021 | 01:01 PM
Yuille36's Avatar
I’m neither of those, and I still disagree with your 5 minute timeline. The difficulty being your on your back, in a contorted position in tight quarters. Now if you were to remove the passenger seat, then less a 5 minute job at best.
Old May 9, 2021 | 01:28 PM
tlambert's Avatar
2005 E55 AMG
lol....that was good for a laugh.
Old May 9, 2021 | 06:02 PM
bobgodd's Avatar
2004 E55
Honestly…. No. The car feels exactly the same as it felt before. The rear air bags shouldn’t cause a harsh ride, as the bags job is only to support the weight of the car, same purpose as a real coil spring. It’s your rear shocks the dampen the ride and they are adjustable for compression and rebound. These shocks aren’t cheap, as they do go bad. Without the rear shocks your car would just bounce around all over the road.
Yea I have replaced both front struts with Arnott units as well as both rear shocks and both rear springs. The rear components are less than a year old. The car just feels extremely stiff. Bumps are jarring, and not at all how I think it should be. Need to hook it up to xentry I guess and see if I can find something wrong. 222k and climbing, so I fear most things will start failing any time now.
Old May 9, 2021 | 06:08 PM
Mercedes CLS 55 AMG
Use a power driver, with a long torx bit, and a short to medium one for the rear cover bolt. It's seriously a very, very fast job. On my older V12 BMWs you had to take the entire dash apart which was almost a 6 hour job. This is a joke by comparison. 5 Minute job.
