W210 E55 2000, Can i use the W211 Brake calipers?
W210's calipers and rotor is expensive than W211. My co-worker has a 99 E55 and he is think to switch to W211's rotor, but can't be done. Maybe there are chance if you use both W211's rotor and calipers together, but no sure if it works.
BTW, C55 isn't the same 8 piston calipers as E55. And, does the system fit under your current rims? Will it fit will be another issue. Maybe CLK AMG's rotor and Caliper might fit into W210 since the size is smaller.
