W211 E55 differential oil (yep, tried "search" first :-)
I have tried looking via search functions on this and other forums. Postings seem split as to what weight is correct for E55 diff. I see 75/90 and 75/140 being claimed as "correct". Also have seen 85/90 listed. What is the current consensus as to the correct weight?
VIN WDBUF76J46A896801 (no P030 option that I can see)
i feel your pain. no one agrees on it honestly. i put it off for over a year and just a couple weeks ago went with mb 75-85. ECS tuning and a couple other sources have it on their sites as being the correct fluid for E55's so i finally just went with it.
https://www.ecstuning.com/b-genuine-.../001989330312/
This fluid falls under 235.7 specifications. i recall reading somewhere that this is the most up to date spec but i couldn't find anywhere in my owners manual what the original was.
This is one of the reasons I posted this. No clear answer across various sites.
The BeVo site, as mentioned above, is a great source for approved fluids per specification. Good luck!
https://bevo.mercedes-benz.com/beam.en.html
When I go to FCP Euro they do not list the E55 for that oil: https://www.fcpeuro.com/products/mer...330310#fitment
I will be doing mine shortly and I will probably be using this.
https://www.amsoil.com/p/severe-gear-75w-90-svg/
That was was what was recommended when the car was manufactured. Manufacturers update fluids and make changes over time which they pass on to the dealers which may or may not be the case here. The difference between the two fluid weights we are discussing here is inconsequential. Many here have used 75W-140. You will be fine with whatever you choose.
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
