Wheel lug pattern MM ?
Old Aug 11, 2021 | 10:47 PM
Fountain35's Avatar
Is the wheel lug pattern on the E55 112 X 5? Looking for a 3mm spacer for the fronts and nobody seems to know.
Thanks in advance.
Old Aug 12, 2021 | 12:09 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
Short of going out to your car and measuring, you can go to a wheel selling site online (tirerack.com? Discounttiredirect.com?) and look up the wheels for your car. They'll list the specs for the wheels most times.
Old Aug 12, 2021 | 09:26 AM
machild's Avatar
Top Answer: 1
2006 CLS55 AMG, 2005 SLK 350 AMG
Thanks in advance.
Another way to confirm is check brake rotor spec's as many report the wheel lug spacing. And for our cars it is 112mm (4.4 in).
Old Aug 13, 2021 | 01:15 AM
Fountain35's Avatar
What's the consensus on wheel spacers? For the SL rims in the front it is advised to use 3mm spacers. Never used them before, 3mm it hardly seems worth it.
Old Aug 13, 2021 | 05:41 PM
cdk4219's Avatar
95 SL600
I would only use that 3 mm spacer if I needed brake or suspension clearance. 3 mm isn’t noticeable for the flush look.
Old Aug 13, 2021 | 07:18 PM
Fountain35's Avatar
3 mm is needed for clearance, rubbing.
Old Aug 30, 2021 | 10:51 PM
Fountain35's Avatar
I put the larger rims on, noticeable size difference, ride is much better which I didn't expect. No spacer needed.
Old Aug 31, 2021 | 03:45 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
5x112 and bolts of m14x1.5. pretty easy to find online. smaller vehicles have different bolt size. The old C230 has a smaller bolt size. both same 5x112, same as Audi.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
