A somewhat different E55
Yeah, the reservoir bracket has been cut and screwed onto the fan housing. I can try to get some better pictures tomorrow maybe.
If possible, i'd try to mount the intercooler cooler at the front, so you get the best cooling effect on it. If you put the AC condenser in front, you won't be able to click the AC condenser in the mounts i believe. If you use the SL55 steering oil cooler, you can get rid of the E55 steering cooler and gain a lot of room and perhaps fit the whole thing in the front. The E55 steering cooler take the most space, since it makes a 90° bend towards the engine bay. I had to cut the plastic where it makes a bend, to gain some clearance.
The next mod(s) have arrived, but the weather is really poop at the moment here and i don't like driving and moving the car in the rain and cold, so i'll wait a few days before mounting them.
GT63 brake cooling ducts and Porsche 997 brake cooling ducts. Not sure how they will fit, but i'll just fiddle and try it out.
Besides that, i have a 2.82 diff and Kleemann camshafts waiting to go in the car
I'm quite curious how the car will feel with different cams
I'm quite curious how the car will feel with different camsYes, I figured the reservoir must have been attached to the fan shroud in some way. Pics would be great if you can get some. But, no hurry - especially if the weather is lousy.
I have been going back and forth on the possible intercooler locations. In the end, how to secure either the condenser or the intercooler or both in some way will likely decide how it goes together. If it actually does go together. But by removing the existing steering cooling system will open up possibilities.
Again, thank you!
without any pulley on yet, it is able to keep iat same as ambient when raining where presumably water on its surface helps, and about 6c above normal driving dry weather, single bosch 010. we will see once 74 fixed, 92tb, 630cc, and headers, installed.
upside, for me at least, is that h/x pushes oil cooler lower so bottom lip down, giving chin more pronounced look, making headlights appear smaller and front of car more rakish. i could have pulled oil cooler around to sit along bottom of h/x, but chose to leave it like that.
downside, is always worried radiator not getting enough air, altho driving with scanner connected suggests no difference in temps, maybe fan on more, and that for fitment, intake scoops deleted, metal side brackets trimmed, horn relocated behind headlight, and hood latch had to be made from slimmer metal bar, so you need bravery.
A fixed pulley does nothing unless you program the bypass valve differently or remove it (different software needed) (Umluft Klappe in the above pictures)
in other words, just want to know if i should have bypass delete with 74 fixed pulley. thx
Did you look at the HE Mercedes used in the early to mid 2000 in the S and other models - part number 220 500 12 03? Any idea on the dimesions and capacity?
SL55 585
PLM XL 1,600
Wheel Well 550
Total 2,735mL
Tell me where I'm missing something
Do you still have airmatic and the secondary air pump? I removed those, so I had the space in the wheel well for a cooler. With these there I don't think it would have fit.
Source: https://ultraracingeurope.com/index....t-h-brace.html
