A somewhat different E55
Old Jun 27, 2022 | 06:34 PM
  #101
austingtir's Avatar
2004 E55 AMG, 2006 CLS63, 2004 ML55, 2014 E350 sport
Originally Posted by nd-photo.nl
Yeah the 4 point H brace is the only one that will make a really noticeable difference. Alot of performance bmw's have that sort of bracing on their front subframes.
Old Jun 27, 2022 | 07:12 PM
  #102
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Does it fit over the belly pans? I have a CLS55, and they have a similar one for my car.
Link: https://ultraracingeurope.com/index....race-2611.html
Old Jun 27, 2022 | 07:46 PM
  #103
austingtir's Avatar
CLS55 is the same.
You can make it all fit with the bellypans with spacers at the front and the trans cover is pretty good other than the front of the trans pan rear of the oil pan cover you probably need to put rubber bushings there and space it off with longer screws from memory.
Old Jun 28, 2022 | 03:17 AM
  #104
CQHall's Avatar
W222 AMG S63
I'm looking to improve the deficient handling of my E55 and this H brace seems to be an inexpensive, low-risk, and reversible way to help with that. Can anyone recommend a reliable retailer for Ultra Racing in the U.S.?
Old Jun 28, 2022 | 11:59 AM
  #105
SICAMG's Avatar
2005 e55 AMG
Ebay has them for sure, just looked.
Old Jun 28, 2022 | 12:22 PM
  #106
CQHall's Avatar
W222 AMG S63
Yes. Any particular retailers that can be trusted and deliver quickly?
None are in the US. Which means any disputes or returns will be a pain in the ***.
Old Jun 28, 2022 | 01:49 PM
  #107
There is a US subsidiary > https://ultraracing-usa.com/
Old Jun 29, 2022 | 10:56 PM
  #108
Saurabh914's Avatar
E63 AMG 2009 E55 AMG 2005 E63 AMG Wagon 2007
I’m going to install a cwa100 as well but wonder what is needed to install it correctly. I already have the bmw socket but wonder what wires I need and if I need a controller. How did you hook yours up?
Old Jun 30, 2022 | 12:05 PM
  #109
UncleBenz55's Avatar
W211 E220, W211 E55, W203 C55
i built my own wire harness for the pump, using thicker cables, cause the stock pump uses 0,5mm² cables which go from the rear (Sam rear) to the front and the pump is only engaged, when the intake temp is above 40°C.
I used following parts:
A000 982 30 26 (2x Kontaktbuchse) Contact Pin MLK1.2S
A001 545 50 80 (2x Aderabdichtung) Rubber sealings for contact pins
A001 545 59 80 (2x Blindstopfen) Rubber plugs
A028 545 27 26 (1x Kupplungsgehäuse) Plug connector
A013 545 16 26 (1x Kontaktbuchse) Contact Pin SLK2.8
N072581000304 (1x 10A Sicherung) Fuse
0,75mm² black cable for +
0,75mm² brown cable for ground
I used fuse terminal F51 on the front fuse box, which is ignition + and wasn't used. Put in a 10A fuse and connected my wiring to Plug C1 Pin 9 which connects to Fuse F51. The wire runs to the pump from there, goes into Pin 4 of the pump (+) and Pin 1 on the Pump is ground. I used the ground connection somewhere under the SBC pump.
For mounting is used the W212 E63s mounts, but i have no pics of that atm.
Mounts:
A212 501 43 20
A212 501 44 20
Old Jul 3, 2022 | 03:18 AM
  #110
Old Jul 3, 2022 | 05:06 AM
  #111
CQHall's Avatar
W222 AMG S63
What were the results of the dyno run?
Old Jul 3, 2022 | 06:14 AM
  #112
Me bring super happy
You can see how the camshafts just keep the power going till redline. Usually the power drops at around 5500rpm where these engines make peak power. Metrics are PS and Nm. 572PS @6500 rpm, and drive train lies is about 102PS so 470 on the wheels. With my headers, cams and throttle body it's very close to a stock clk dtm engine. With different pistons and a bit more compression of come very close to it I think
Old Jul 3, 2022 | 01:33 PM
  #113
Nice work brother! Was ths purely a dyno run, or was it mapped?
Old Jul 3, 2022 | 02:18 PM
  #114
CQHall's Avatar
W222 AMG S63
Well done!
To convert those figures:
  • Max Power at the crank: 573PS (565HP) @ 6500RPM
    • Stock: 476 PS (350 kW; 469 hp) @ 6,100
    • Power Gains: 20.4%
  • Max Power at the wheels: 478PS (471HP) @ 6500RPM
    • Drive train loss: 102PS = 101HP
  • Max Torque: 746Nm (550lb-ft) @ 3710RPM
    • Stock: 700 Nm (520 lb-ft) @ 2,650
    • Torque Gains: 6.6%
Old Jul 3, 2022 | 02:38 PM
  #115
Thank you for converting the numbers
I forgot to say, these numbers are on a stock 0580 Supercharger with a stock pulley milled from 91 to 88mm. Crank pulley is stock and no belt wrap kit.
I wonder if a SL55 Mj2002 intercooler would perform better 🤔 I'm curre tly using the stock one with a plate on the bypass opening
Old Jul 3, 2022 | 02:41 PM
  #116
Thank you! I got the car tuned on the dyno after installing the cams
Old Jul 4, 2022 | 07:10 PM
  #117
Why is the torque still around stock?
Old Jul 5, 2022 | 12:47 AM
  #118
Because of the low boost. Once you add a bigger crank or smaller sc pulley the torque goes up to around 800-850Nm. The cams also sacrife a bit of torque.
Has anyone by chance measured stock boost? I never measured it on mine with the stock size pulley
Old Jul 5, 2022 | 07:39 AM
  #119
Ah that explains. Will you be having plans to go the 77mm route (clutched or unclutched)?
Old Jul 5, 2022 | 07:44 AM
  #120
No, that's too much boost for my liking. I think the intake temps would go up too much on the Autobahn and the wear is definitely not good for the supercharger. I'd also need a bwk with such a pulley
Old Jul 5, 2022 | 02:51 PM
  #121
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
There is some seriously excellent technical information in this build thread. Outstanding work and kudos to you!
Old Aug 21, 2022 | 06:49 PM
  #122
machild's Avatar
Top Answer: 1
2006 CLS55 AMG, 2005 SLK 350 AMG
Yeah I think SL55 cooler with power steering cooler will be the best fit, but it won't be plug and play. Please share your results once you've changed your setup, will be interesting to see
I'm not done with this retro fit, but I can report some info.
I do have the SL55 HE (can't remember if I had mentioned that) with the additional oil cooler. I have removed the bracketry for oil cooler and mount that cooler to the face of the HE with bolts through the coils. I have taken apart enough of my car to dry fit this HE in front of the condenser to confirm the condenser tube can run between the HE and the condenser as it currently is. The final step of this plan is to mount the HE to the condenser the same way you did with the S55 HE. With this configuration the stock power steeing cooling coils will be eleminated which will allow for easy location of the SL55 HE in that space and the oil cooler that came with the SL55 HE will be in front of the HE and used as the PS cooler.
Some details on the SL55HE. The overall sizing is: 620mmW x 410mmH x 27mmT. The coil alone is 585mmW x 407mmH x 24mmT. The measured capacity of this HE is 1,000mL. I was surprised and very pleased with the volume of it. The next step in the plan is to use the larger PLM under bumper type HE (similar to stock) to replace the stock unit, The combined volume of these two HE would be a total of 2,600mL.PLM XL HE is 1,600mL and the SL55 HE is 1,000mL.
Old Aug 26, 2022 | 07:37 AM
  #123
daryel.corran's Avatar
LX
I too own a Japanese spec and still stock with just wheels changed. What interested me most is the CLK DTM throttle body. This has been in my wishlist but I’ve been concerned on how it would work without the byepass valve without programming.
Old Aug 26, 2022 | 06:25 PM
  #124
You can get the 80mm throttle body from the SL55 with snout that he's the bypass opening. It's less of a headache honestly.
Old Aug 28, 2022 | 03:30 AM
  #125
Went to schöne Sterne (biggest Mercedes meet in Europe) yesterday and found a twin of my car. Talked a bit with owner and took some pictures, I thought I would share here. His car looked exactly like mine two years ago, even with the window tint, so it was like travelling back in time.
