A somewhat different E55
Old Nov 28, 2022 | 09:11 AM
  #151
machild's Avatar
Top Answer: 1
2006 CLS55 AMG, 2005 SLK 350 AMG
Originally Posted by UncleBenz55
I picked it up with 205000km and it now has 206000km. The 722.649 will replace the 722.643 in my E55 and the 2.82 will replace the 2.65 diff on it too
What models used the 649 trans? How is it different from the 643?
Old Nov 28, 2022 | 12:44 PM
  #152
UncleBenz55's Avatar
W211 E220, W211 E55, W203 C55
The V12 models had the 649 and have a different torque converter and the transmission itself has more clutch packs and is rated for 1100Nm iirc.
Old Nov 28, 2022 | 12:57 PM
  #153
machild's Avatar
Top Answer: 1
That's what I was thinking it likely was. Thanks for that.
Old Mar 5, 2023 | 03:09 AM
  #154
Alex e55's Avatar
E55 AMG W211
Originally Posted by fazxs
Congrats, nice car and thanks for sharing. I too own a Japanese spec and still stock with just wheels changed. What interested me most is the CLK DTM throttle body. This has been in my wishlist but I’ve been concerned on how it would work without the byepass valve without programming. To my knowledge, only German tuner MKB offers this in their M113k packages. Any information you can share in this would be of great help. Please do share the part number.
How much weight did you save by replacing the seats, sure it must be substantial.
Like many Japan spec car owners, I feel the audio head unit is a sore point. I’d love to shave a few kilos of the wiring as I plan to upgrade to a unit with apple CarPlay. Any tip here would be great!
Enjoy your car in the lovely Autobahns….
hello. the bypass valve can be disabled by star diagnostic equipment
Old Mar 5, 2023 | 05:02 AM
  #155
You need a different base file, either clk dtm or Sl55 modelyear 2002. You can't code out the bypass valve.
Old Mar 5, 2023 | 03:36 PM
  #156
Alex e55's Avatar
E55 AMG W211
in star diagnostik, I saw a function to turn off the bypass valve. Or am I mistaken?
Old Mar 6, 2023 | 04:14 AM
  #157
Probably something else
Old Jul 23, 2023 | 06:20 AM
  #158
The last couple weeks I started buying some parts for the E55. I've been wanting to upgrade my rear brakes to match the 390mm brakes on the front. So I found two rear calipers from a W212/218/204 Black Series and got them powder coated in the oem style silver colour. I replaced the dust boots and got new brake pins and pad springs from Mercedes. For rotors I got Brembo 360mm ones and paired them with Pagid Street Plus pads. For the front I changed the pads to Ferodo Ds2500 pads. I'll let the pictures do the rest of the talking
Old Jul 23, 2023 | 07:20 AM
  #159
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
They complement your front brake upgrade perfectly in regards to optical styling (same type design of the caliper etc). Well done man!
Old Jul 23, 2023 | 09:27 AM
  #160
machild's Avatar
Top Answer: 1
You beat me to it. I too have a set of the W212 calipers. I haven't been able to get them re-power coated because no one around here knows what color to use and I can not find any AMG decals in a material that will hold up to the 400*F baking process used as part of the power coating process. Do you know or can you ask your powder coater the Hex Decal color code they used and what decal source they have? Your calipers look fantastic.
Old Jul 23, 2023 | 11:58 AM
  #161
The colour name of the oem caliper is Graumetallic 7MB TAB.19.15. The powder coat guy had colour cards and took the closest silver he had
Old Jul 23, 2023 | 02:31 PM
  #162
machild's Avatar
Top Answer: 1
Ok, thanks for that. I'll see if what the shops I have been talking with can do with that info. Any idea on a source for the decal?
Old Jul 23, 2023 | 03:53 PM
  #163
The shop had them already, i didn't supply them. On my calipers , they powdercoated the caliperr, then put the stickers on and then put clear coat over it. I got the front ones done 2 years ago and they still look good
Old Jul 23, 2023 | 05:15 PM
  #164
machild's Avatar
Top Answer: 1
Yes, those steps are what I want done also. But, sourcing the decal has proven difficult. They all seem to be nylon which would melt in the curing process.
Old Aug 12, 2023 | 05:52 PM
  #165
machild's Avatar
Top Answer: 1
Now that you have had some time with the upgraded rear calipers and rotors, what impressions do you have of the braking now? Those rear calipers have much larger pistons and with the increased rotor diameter, it seems that the braking bias would be noticably more to the rear than in the past.
Old Aug 12, 2023 | 06:34 PM
  #166
It's been pouring for the last 3 weeks and i haven't had a chance to even bed in the pads yet and try out the new brakes
Old Aug 12, 2023 | 06:37 PM
  #167
machild's Avatar
Top Answer: 1
Well dang, that's got to be frustrating. Let us know when you can do a proper test of your good work.
Old Dec 1, 2024 | 02:45 AM
  #168
Since I haven't updated this thread in a good while, I'll bring it up to date. I unregistered the E55 in October 2023 and parked it in my garage. It's been sitting there for over a year now since I started my master certified tech course this year.
However in May I sold the CLS500, which I was using as a daily, because I wanted something more compact and less boaty. So in June I bought the most clapped out C55 in europe. I have been fixing, restoring and modding that car since June. It's been a true challenge, but feels kind of rewarding, knowing I'll have rebuilt most of the car myself, when I'm done.
If there's an interest, I'll cross post the updates on that car here. The thread is located here:
https://mbworld.org/forums/c32-amg-c...55-europe.html
Old Dec 1, 2024 | 06:49 AM
  #169
I have been following this for a while and the work and effort you put in there is admirable. Keep doing what yo do my man!
Old Dec 1, 2024 | 09:27 AM
  #170
SICAMG's Avatar
2005 e55 AMG
I don't know whats more impressive......the car or the gas station LOL !!!
Old Dec 1, 2024 | 08:00 PM
  #171
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Please cross post. I saw the thread title in "new posts" but passed on it as it was a C55. Sorry!
I didn't realize it was you. For what it is worth, when you post I read. You provide valuable technical and historical information on our Mercedes vehicles. I like to think I am knowledgeable about Mercedes. You, however, always bring new and interesting information to the party and I thank you for that.
So ... please cross post.
Old Dec 1, 2024 | 09:24 PM
  #172
tlambert's Avatar
2005 E55 AMG
Yup I always read the project threads also. Post them up!
Old Jan 10, 2025 | 04:43 PM
  #173
I've been quite busy with this car. The C55 is almost naked now and we'll be replacing a part of the upper beam on it, since it was all bent to an unrepaired accident damage.I took out the front subframe with drivetrain and the rear subframe. The interior is also out and it's pretty much just the chassis with some wires left. I don't think it's too often, that you can see a chassis this empty, so here you go
Thread is located at https://mbworld.org/forums/c32-amg-c...55-europe.html
Old Jan 10, 2025 | 05:08 PM
  #174
SICAMG's Avatar
2005 e55 AMG
Couple things here.....
One,holy sheeet thats impressive to see and comend you on a lot of work.
Two you look at this and say WOW but the fact that all those parts have to be put away and organized is a whole other ball game of impressive !!!
Old Jan 11, 2025 | 08:24 AM
  #175
I made sure to bag all the bolts and nuts of subgroups in labelled bags haha
