Installing video of coil overs on a e55
Received 1,488 Likes
This place is a joke.
I've driven two E55's with coilovers and both rode like shi*. The airmatic is superior, and there's really no reason to get rid of it, other than owning a car you can't afford. With the Arnott options, or new Billstein struts, it's not a big deal. Last year around 150k miles I installed reman Arnott fronts, arnott rears, new oem compressor and valve block. I'm good for many years now. I can raise my car over speed bumps, lower it with DAS/STAR, and change the stiffness with the pushbutton. Airmatic also does other things most aren't aware of. It prevents dive on braking and more.
I held off on this forever with my SL55 which has Hydraulic shock set up , I finally switched,not because I had any current issues , because I wanted to hook at the track, the ride is the exact same , I opted for KW coil overs and have both VVT sway bars installed, only thing I can complain about is not being able to raise and lower the car and after a few drives I was over that ,
E55Greasemonkey (10-26-2021)
That’s more of an opinion than anything. The coilovers give you peace of mind NOT failing you when least expected. Ride quality is subjective, as is your feeling of airmatic being superior. I prefer the coilovers to airmatic. Why keep fixing the same problem with the same failing parts?
E55Greasemonkey (10-27-2021)
