►►►►Best Remote Programming & Diagnostics service
Old Nov 6, 2021 | 09:42 PM
BenzNinja's Avatar
Former Vendor
Exclamation ►►►►Best Remote Programming & Diagnostics service
100% 5 stars rating since the beginning
Still hesitating if you should spend a little more to get the best ?
https://benzninja.com
Old Nov 7, 2021 | 08:37 AM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
Not hating but what's with the BMW 8-series on the lift?
Old Nov 7, 2021 | 10:10 AM
BenzNinja's Avatar
Former Vendor
MB was out of stock
but, uses the same protocol
Old Nov 23, 2021 | 04:29 PM
CQHall's Avatar
W222 AMG S63
How does this work? I need some suspension coding (lower it some). Can this be done remotely? Do I have to install software on my PC?
Old Nov 25, 2021 | 08:49 PM
CQHall's Avatar
W222 AMG S63
@BenzNinja , can you help me with my questions above? I want to use your services, but I need more info.
Old Nov 26, 2021 | 11:48 AM
BenzNinja's Avatar
Former Vendor
Hi
use the contact form please
Old Dec 12, 2021 | 05:29 PM
Alex e55's Avatar
E55 AMG W211
Hi
Can you program the disconnection of the m113k compressor clutch?
Old Dec 12, 2021 | 06:40 PM
BenzNinja's Avatar
Former Vendor
I can program everything that can be but what would is the idea behind your request
Old Dec 13, 2021 | 01:50 AM
Alex e55's Avatar
E55 AMG W211
Hi
The fact is that when the compressor clutch is turned on, it remains stuck for a long time until the machine stops. I would like the clutch to disconnect earlier.
Old Dec 13, 2021 | 04:35 PM
BenzNinja's Avatar
Former Vendor
I don't think that there is a delay parameter
Old Dec 15, 2021 | 05:35 PM
Alex e55's Avatar
E55 AMG W211
hello. please tell me. i installed more efficient injectors from slr. and i got a rich mixture error at idle. i understand that i need to reduce the gasoline supply at low speed in the engine firmware. am i thinking right?
Old Dec 15, 2021 | 07:43 PM
BenzNinja's Avatar
Former Vendor
Hi
yes
needs adjustments in the engine ecu
Old Dec 28, 2021 | 08:12 PM
BenzNinja's Avatar
Former Vendor
Old Jan 11, 2022 | 10:34 AM
Alex e55's Avatar
E55 AMG W211
Hi
yes
hello. please tell me how to solve this problem, my e55 cannot do a burnout. how to make the esp system turn off completely? shutdown via dino mode does not suit me.
