Anyone in Bay Area know how to fix w211 door handle?
Old May 23, 2022 | 12:57 PM
jchen6's Avatar
2019 Model X DM | 2007 E63 | 2006 E46 M3
I was wondering if anyone was handy and knew how to fix my e63 w211 door handles. I had the front driver side fixed but the 3 others buttons started failing.
Old May 23, 2022 | 04:45 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
I recommend you just replace the handles. Only takes 30-45 minutes the first time and at least on the front doors, you do not need to remove the inner door panel; all work is performed from the outside.
The linked thread is missing the photos but if you go to post #158 and then to 4:30 in the video it will show you how easy it is for the front handle. There is another post or two in the thread which shows how to repair although that is no guarantee. Also a couple of posts concerning the rear door handles.
https://mbworld.org/forums/w211-amg/...ent-diy-7.html
Literally pull back the weatherstripping, loosen the T20 torx screw, remove the lock assembly with the key cylinder while carefully disconnecting the wiring harness, slide handle a quarter inch over and gently remove while disconnecting the Keyless-Go connector. Assembly is the reverse of disassembly.
Old May 24, 2022 | 05:05 AM
bobgodd's Avatar
2004 E55
I'm guessing OP is asking specifically about keyless go handles, which I think are quite difficult to get these days. My dealer and autohausaz have told me they cannot get anything anymore, in any color.
I've tried eBay, but had to send back as the buttons didn't work.
