E55 Engine mounts needed or is it fine?
Old May 28, 2022 | 07:57 AM
Gripen's Avatar
2004 Mercedes E55 AMG Wagon
Hi All,
Last year I bought a W211 E55 wagon as a project car and am doing things when budget allows :p I read that the engine mounts fail a lot on these and am wondering if I should be replacing mine so wanted to check your opinion on it.
I have created a video of the engine while running idle in P and then pressing the gas pedal to about the middle (I would say?). Reading a bit about the movement I now have the feeling it's not that bad? I also see no leakage when looking at them. They might have been replaced at some point but I just have no documentation of any work done on it before 2014 (missing 10 years almost!) unfortunately.
Old May 29, 2022 | 07:54 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
To be honest, it also looks fine to me. I just bought a CLS55 not too long ago and will be replacing the engine mounts as preventative maintenance. They are not that expensive, so might as well change them! It helps get the power down and provides less strain on the exhaust etc.
Old May 29, 2022 | 08:14 AM
Gripen's Avatar
Hey nd-photo.nl, thanks for the reply and your opinion, to my eye it seems fine as well but just wanted to check if there are people that had them fail and know how they behave at that point. I think for now I'll leave it as it is.
Nice to see someone from The Netherlands with a M113K as well !
Old May 29, 2022 | 05:20 PM
Didnt even notice you are also from NL haha
I will send you a DM, might be handy to stay in touch
Old Jun 9, 2022 | 01:37 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
OEM mounts do wear out a lot and mostly loose the oil in them. Most replace with Black series mounts that are a huge improvement over the oil filled style.
http://ultimatepd.com/mercedes-black...712400118.html
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jun 10, 2022 | 05:27 PM
G_MAN_NH's Avatar
2016 C300
I just installed Black series mounts and I was shocked how much I had to jack up the engine to get the new ones in. The old mounts had collapsed quite a bit. I would say yours should be changed. My car has 103k miles on it. I also replaced the trans mount with the black series mount. My trans mount was also collapsed. It was still intact but in bad shape. The black series appears to be much better. My engine did not have much movement either...
Old Jun 12, 2022 | 06:01 AM
Thanks for the tip!
