Check oil level not displaying
There are two ways I interact with mine and this is super old hat for the W211 cars:
- Ignition to position 1 (or one press of KG button, foot NOT on brake). Scroll to whatever the main menu is and then press arrow up. It will say whether oil level is OK, too high or too low and what to do.
- Ignition to position 1 (or one press of KG button, foot NOT on brake). Press cluster button 3 times. Press arrow button up (or down, I forget). Ignition switch to position 2 (or press KG button again, foot NOT on brake). It will give you an actual quantity which in my experience is not the true number. Should read ~7.7 or 7.8 quarts after an oil change. On mine when it gets down to about 6.8 it will say to add 1 quart in the OTHER menu so this seems quite consistent.
It just makes me do all of this if I want to understand my oil level, which is annoying. But I don't have the --- issue like the OP....
If you haven't got dipstick... buy one.
