How to make the ball joints be quiet
Hello, I am waiting to get new ball joints in the front, already replaced some but others sqeak like 1950s car. Anything I can do to make them be quiet while the others arrive?
My car https://www.instagram.com/fast_cl55/
2005 CLS55 AMG W219 C219
Straight pipe it in the meantime?
Turn up the audio?
All jokes aside, I dont think there is anything that you can do, as ball joints are enclosed in a rubber jacket. Maybe punch a hole in the rubber boot and inject grease of some kind?
Turn up the audio?
I personally never heard ball joints squeak, but clunk. I believe it might be your bushings that are squeaking. It could also by your sway bar bushings.
But what was it @MartinWake ....
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I had a squeak on my S550. It was the main lower ball joint. I tried injecting grease and while I was able to fill it, the noise was the same. Then I had the car in the air for an oil change and injected more grease hoping that it might flow around with the weight off the joint. When I put the car down and test drove it, the noise was gone and has been gone. Makes me wonder if injecting grease every once in a while could seriously prolong the life of our many ball joints. FWIW, I tried squeezing out the excess grease from the hole I made with the needle injector and it would NOT flow out no matter what I did. The rubber acted like a check valve somehow. So any worries of water penetration are unfounded I guess. And regular servicing could mitigate the risk further...YMMV
SlavShreds (08-05-2022)
