Brembo Two piece Rotors 09.9764.23
Old Sep 29, 2022 | 06:30 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Simple question… Thinking about upgrading to these on the E55 ..
I would have thought the rotors were directional as the vanes spiral inward on the right wheel and outward (as it should) on the left wheel?
Can someone confirm this is the case please?
Old Sep 29, 2022 | 09:10 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
If you look at the specs and the picture, it shows that the discs do not have directional vanes.
https://www.bremboparts.com/europe/e...isc/09-9764-23
I bought similar discs for my Mini Cooper S R53 (albeit single piece) and they also didnt have directional vanes. I believe Brembo calls it PVT > https://www.bremboparts.com/europe/e...me/brake-discs
Old Sep 30, 2022 | 12:41 AM
UncleBenz55's Avatar
W211 E220, W211 E55, W203 C55
Same partnumber for left and right, like on the E63 and CLS63.
However for their price point I don't find them to be worth it, unless you really want to reduce unsprung mass.
Old Sep 30, 2022 | 03:31 AM
stevebez's Avatar
Thanks guys … yes didnt realise the PVT system … was fooled by the spiral drill holes.
Yes besides the braking benefits the reduction in unsprung mass is what I am after
Old Sep 30, 2022 | 06:13 AM
DBA use something similar with their "kangaroo paw" technology
https://dba.com.au/tech-zone/product...w-ventilation/
Old Sep 30, 2022 | 09:24 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Also, if you look at the OEM rotors, you will see that the crossed drilled holes and slots are in the same direction left and right. They used the same rotor for either side.
I assume, that this was for cost savings. As it cheaper to just make one rotor for both sides, instead to making a true directional rotor for both sides.
But, since the cooling vanes aren't directional, Mercedes-AMG could get away with it.
