Wiper fluid leak and other maintenance
I made sure the vac line didn't touch the body and despite looking like a mandrel bend, there is no lack of flow or pressure at the nozzles.
Also been putting this job off as well. I have done it twice before on a M112 and M113 so wasn't looking forward to the cleaning. Figured might as well do it before the rear main seal is replaced as the RMS will fail again if the breather holes are blocked. Order two oil cap seals to replace both the cap and the filler neck on the breather cover. These are usually leaking by this age too. You can also buy a whole new filler neck if need be, they aren't expensive. I only use genuine mercedes for the cover gaskets, they are cheap enough but there were issues with some of the aftermarket brands in the past. Torque is 9Nm for valve cover, 4Nm (I used 5 as that is my lowest torque wrench) for the breather covers, 8Nm for the coil packs. Don't reuse the aluminum bolts, get stainless M5, 16mm long.
For some reason I have replaced this centre cap about 3 times and they keep going black. Only this one, the others are probably the factory originals.
I also replaced the power steering reservoir as they updated the filter in it I believe and my PS was groaning despite adequate fluid. I sucked out the old fluid with a syinge and vac hose on the end. I measured out how much was removed but still managed to overflow it everywhere when refilling. Anyway it is an easy job, there is one large clip to pry out with a small screwdriver. There is one E10 bolt somewhere under the oil filter housing. and a single hose. It slides out towards the radiator quite a long way. To bleed run the steering from lock to lock 30 times. I had the car up on jackstands for this. I did it with the car off to start and then finally with engine running. Reservoir 000-460-01-83-MBZ, seal that goes inside reservoir Part #: 000-466-18-80-MBZ, clip that holds it on Part #: 000-994-19-03-M22. I suggest trying a dry run install of the reservoir first before putting the seal in. It is quite tight. I put the seal on the metal pipe and used some PS fluid to lube it up otherwise I doubt it will go on very easily.
Once the nylon cord broke it was also game over for the fuel cap. I suggest OEM only as the fuel system can be very sensitive to pressure.
