M113K supercharger tensioner pulley bearing?
Does anyone know what the part number for bearing in the SC tensioner pulley is? I just had the bearing in the accessory belt tensioner seize up and leave me stranded. The tensioner is fine, so I would just like to replace the bearing if possible.
2006 CLS55 AMG, 2005 SLK 350 AMG
I have replaced a number of the and at some point posted here of the forum. Here is a small chart I had put together back then - two years ago so prices are probably higher today.
Yes, that's how I replaced the bearings - looked at the old bearing and got the number. I now keep the numbers in case I or other members need them. By having the bearing numbers ahead of time they can be ordered and on hand when the project is started. No down time.
Drill out the rivits and you have two halfs and a bearing in your hand. I used 4mm (I think it was that size) bolts and nylon locking nuts to put the two halfs back together. Cost me about $13 and 20 minutes.
Yes, that is why I asked for the number. I wanted to get the bearing on order without taking the car apart first.
I bought the Febi Bilstein tensioner not so long ago but they are (very) hard to come by these days it seems (same partnr that you mentioned @machild ).
