You can now lower your cars using consumer scanners
Old Feb 6, 2023 | 02:46 PM
CQHall's Avatar
W222 AMG S63
When I had my E55, I had a shop use STAR to lower it (before I installed coilovers)...well, now you can do it via some Autel and Foxwell scanners.
Yesterday, I lowered my W221 S63 about 1-inch using my Autel MaxiCheck MX808 (around $200-300).
Online citations:So, if you are running stock suspension and want to lower it some, here's a nice way to do it in your garage.
Old Feb 6, 2023 | 03:32 PM
eightysixtuned's Avatar
W211 E63 AMG
This has been possible for years. The concern with this is that when you modify these values, if you ever want to go back to original without knowing the previous values, you'll be in for $600+ at the dealer for realignment of heigh sensors, plus alignment of vehicle. So, upwards of over $1,200 all in is what I paid.
If you do this, make sure you write down your previous values!
Old Feb 6, 2023 | 05:30 PM
cdk4219's Avatar
95 SL600
And loosen all of the control arm bolts to relieve the added twist to the rubber bushings that will fail sooner because they are on a permanent bind not that the arm has moved.
