Bypass valve readings
Old Apr 10, 2023 | 08:23 PM
SICAMG's Avatar
2005 e55 AMG
Looks like the RPM belts I ordered where canceled because they are no longer made so that sucks.
Really don't want to run a 50lb tensioner. Thats a lot of pressure on that belt and pulleys.
Old Apr 10, 2023 | 08:26 PM
nemiro's Avatar
2004 Crossfire (w/M113K), 2008 Crossfire (w/M156), 2008 ML63, 2018 AMG GT
I went to a larger crank pulley (180mm), and this took car of all of the belt slip issues. One of the better decisions I made regarding this.
Old Apr 10, 2023 | 08:52 PM
SICAMG's Avatar
2005 e55 AMG
Yea I know. a 180 and stock upper would probably do the trick but I have had so many pulleys on this car I just cant see buying more but may have too. With my se up there should be zero slip but there is still some that will loose around 1lb or so now. You can even see it in the logs, it climbs,drops a little,climbs,levels off then starts to drop.
​ ​ ​ ​ ​ ​ My worst thought is it will be "better" but not 100% with a complete change of pulleys.
Old Apr 10, 2023 | 09:02 PM
nemiro's Avatar
Going with the larger lower then adds options to stack. I have the stock 90 for now, but may opt for an 83mm upper in time.
Old Apr 11, 2023 | 07:06 AM
SICAMG's Avatar
2005 e55 AMG
Even going from my now 77 to an 83 really doesnt add a huge amount of belt surface and your spinning it harder with say a 175-180. Who knows...
Old Apr 11, 2023 | 07:18 AM
nemiro's Avatar
The 180/90 combo is equivalent to stock/77, but adding surface area, not taking it away, along with more wrap at the crank.
Old Apr 11, 2023 | 08:12 AM
  #32
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Ow wow, first time heard of this. RPM series in total or the specific ones that you bought?
Old Apr 11, 2023 | 08:24 AM
  #33
SICAMG's Avatar
2005 e55 AMG
The ones I ordered and all other listings are no longer in stock or being sold from what all the contacts I made have told me.
Will look into the 50lb tensioner and find some people that have run it and get there opinions.
Old Apr 11, 2023 | 08:42 AM
  #34
nemiro's Avatar
50# tensioner just seems like an incredible load on that first main bearing.
Old Apr 11, 2023 | 11:51 AM
  #35
SICAMG's Avatar
2005 e55 AMG
I know !! Back in the day I had a Ford Mustang with a supercharged 302 engine. I ran a Paxton Novi 2000 that made 25lb's of boost with a cog drive belt system. It took a few try's to get the front bearing from wearing far faster than the rest from the huge load on the crank snout under boost. More clearance, higher oil pressure and coated bearings did the trick.
Old Apr 12, 2023 | 01:47 PM
  #36
SICAMG's Avatar
2005 e55 AMG
Gave it a lot of thought and have gone back to the bypass valve. With the bypass plate installed the load on the blower created a lot more belt slip and the data logs showed a lot of peaks and valleys in the boost climb. For dag racing this would have worked better but not for the way I race/drive.
The boost/torque on the low end was WAY more than needed and I needed that in the upper rpm.
So now my only thoughts at this point are the engine is using more air than the blower can push or it is at it's limit.
I would like to swap out the crank pulley and spin the blower a little more and see what it does but the belt slip still needs to be delt with. Im going to try some belt dressing thats real sticky and see what it does.
