help! Brake squeal - Akebonos
Old Mar 30, 2023 | 08:22 PM
Apollo90's Avatar
CLS55 AMG
Hi there,
2006 CLS55 owner here. I've just replaced my OEM rotors and pads - I went with Zimmerman rotors and Akebono ceramic pads. I am getting a VERY loud squeal from my passenger front brake since the change and it's driving me crazy. I am used to some brake squeak with these cars especially when very hot and very cold, and its usually bearable.
I've been back to my independent mechanic with the complaint, and he ha suggested resurfacing the rotors and pads, which he did, and he relubed all the components. It was good for a couple days, but it is back again loud as ever. He now suggests a new caliper. I took the car for a second opinion, they did the same thing - disassemble, lube, anti-squeal paste/gel, reassemble, and said the caliper is fine. Before I shell out 1200 bucks for a new caliper, I'd like to exhaust all other options.
I've seen so many threads on this topic, but very few with any solutions. Any help here would be appreciated. It's really driving me crazy.
I am also getting a very weird mouse-like squeak when the pedal is depressed, which I've learned is related to the SBC pump and potentially there being air trapped in the lines. I don't know if these are related, but the car is going to the dealer on Monday for that issue.
Thanks very much
GH
Old Mar 31, 2023 | 01:24 PM
Fountain35's Avatar
Originally Posted by Apollo90
Hi there,
Thanks very much
GH
Try a set of new front pads.
Old Mar 31, 2023 | 02:28 PM
MJBelcher500's Avatar
2006 E55
A set of those pads is around $150. Not sure I would pay that just to see if that is the problem.
You might try knocking the edges of each pad down with a file. Sometimes the sharp edges can cause noise. From what you wrote, it does not seem like you are a DIY person. Having shops try all these things is going to get expensive. Are you able to do any work yourself?
Old Mar 31, 2023 | 02:36 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
First, I would try a high speed run, and then smash the brake pedal to the floor for a few runs. And then see if that fixes your squeal.
Often times, it's due to moisture either on the face of the rotor or the pads. Or the pads aren't sitting flush in the calipers.
Old Mar 31, 2023 | 02:52 PM
Fountain35's Avatar
Thumbs up
I agree it's not cheap but it's cheap compared to the other route he is about to take. He can also keep them and use them at the next brake change if they didn't fix the problem. Check for wear/worn marks on the brake assembly parts as well. Filing is also a good idea.
Old Mar 31, 2023 | 04:07 PM
2006 E55
I agree with Yuille. I assumed that they were already bedded in, but I shouldn't have. This might just do the trick.
Old Mar 31, 2023 | 08:36 PM
Apollo90's Avatar
CLS55 AMG
Thanks guys -- I will give this a go today and report back.
I did call Akebono and provided them a thorough rundown of the issue. They said that their pads don't like Zimmerman rotors for some reason (but the sound is definitely only coming from one wheel, not all four corners) and that they think it's the caliper.
Old Mar 31, 2023 | 10:04 PM
2006 E55
I run Zimmerman rotors on my car along with Akebono pads and have not had any noise issues.
Old Apr 3, 2023 | 08:47 PM
Fountain35's Avatar
GH,
Any resolution on this ?
Old Apr 4, 2023 | 12:48 PM
Apollo90's Avatar
CLS55 AMG
@Fountain35 The above methods (rebedding procedure) did not fix the issue. I've gone ahead and purchased a used set of front calipers that look like they're in really solid shape -- They've arrived and I am really pleased with their condition. I will re-seal the pistons and install (should be Thursday-Friday) and will report back! Thanks all.
Old Apr 4, 2023 | 02:07 PM
PeterUbers's Avatar
Just to chime in I have akebono pads and Zimmerman rotors on my 550xi and did have some squeal after 500 miles and used brake cleaner twice and it went away now for 2000 miles .. not a big fan of the lower initial bite of these pads over OEM but I do like no dust
Old Apr 4, 2023 | 05:08 PM
machild's Avatar
2006 CLS55 AMG, 2005 SLK 350 AMG
Almost all brake squealing comes from the pads vibrating against the rotor. This can be caused by a caliper not fully releasing and not allowing the pad to move (very slightly) from the rotor. With fixed calipers such as we have on our cars that could be from at least one of caliper pistons stickling a bit and not fully releasing when the brake pedal is no longer being depressed. The squeal can also be from the pad makeup so the application of anti-squeal paste is the product to use in that siutuation.
Old Apr 4, 2023 | 08:00 PM
Apollo90's Avatar
CLS55 AMG
@PeterUbers I agree; initial bite is not as good as the OEM -- but i can live with that if they are quiet and produce less dust! Also, the squealing I hear today is not normal - it is incredibly loud and sustained all the way through braking. It's extreme.
@machild Yeah, I think for the reasons outlined above that this truly does sound like a caliper issue. Expensive, but not the end of the world. Do you use an anti-squeal paste you'd suggest?
Old Apr 4, 2023 | 10:11 PM
Fountain35's Avatar
I have the same set up and mine never squealed but I agree the initial bite isn't like the OEM pads. I like you could not deal with the OEM dust. I may look for something different next time.
Old Apr 4, 2023 | 11:12 PM
PeterUbers's Avatar
yep I won't use akebono again, will use OEM pads .. I drive my car more than I look at the wheels so don't really care about dust anymore
Old Apr 5, 2023 | 07:29 AM
machild's Avatar
I keep this in the shop and only use it when needed:
Old Apr 6, 2023 | 06:59 AM
Yuille36's Avatar
one of the ways that you can eliminate brake squeal is to use brake paste everywhere that the pad makes contact with the caliper. The squealing occurs becuase the pad is vibrating against the rotor or caliper. If you can eliminate that vibration, you will have no more squealing issues.
I use brake paste on the back of the pads, on the edges where the pads sit in the caliper, and where the pins go through the caliper and pads. And also where the spring clips touch the top of the pads.
Old Apr 11, 2023 | 09:23 AM
Apollo90's Avatar
CLS55 AMG
Hi everyone:
just wanted to provide an update here. I got my car back yesterday after installing a new caliper. Squeak is gone. Fixed!
The “leading” piston on the inside of the caliper was seized - it was glazing the rotor and the ceramic brake pad, creating a horrendous sound.
It is probably rebuildable, so I will do that, and now I have another full set of calipers should this happen again.
thanks for all the helpful replies! cheers.
Old Apr 11, 2023 | 09:43 AM
Yuille36's Avatar
Hi everyone:
This is why it's important to change your brake fluid every two years, as brake fluid is hydroscopic and absorbs moisture.
This could have contributed to your stuck piston issue. Having a seized piston that caused your glazing and squeaking issue, could have also warped your rotor.
Old Apr 12, 2023 | 09:41 AM
Apollo90's Avatar
CLS55 AMG
thanks for this and great point 👍🏼 I’ll keep that in mind. god knows how old that fluid was. Also, living in Phoenix, I find myself replacing lots of dry, cracked 17 year old rubber bushings! Piston seals were not in great shape.
